ᐅ What are some practical tips for everyday use of Ikea Brimnes furniture?
Created on: 10 Nov 2022 14:37
bramfaHello everyone,
I am currently considering how to best use the Ikea Brimnes range in everyday life, especially in the bedroom and possibly as additional storage in a rather small apartment.
What practical tips and tricks do you have for using Brimnes, such as for organization, handling the materials, or clever modifications? I am particularly interested in how to use the drawers and compartments most efficiently, which everyday hacks make living with Brimnes easier, and if there are any insights on how durable the construction really is with long-term use.
It is also important for me to know how to configure the furniture so that usage is optimized even in limited space. Perhaps there are hidden advantages through modular combinations that are not immediately obvious.
I look forward to your practical advice and very concrete recommendations!
Hey bramfa,
I’ve been using Brimnes in my bedroom for a few years and can share some small but helpful tips that might make your daily life easier.
- Use shallow storage boxes in the drawers. This reduces clutter and helps you find everything faster.
- The doors of the Brimnes units work well with hooks, for example for keys or light bags.
- I use a combination of drawers and wardrobe units for storing seasonal clothing. This keeps the room nicely organized.
What I especially like: you can unscrew the drawers and customize them further with shelving systems or additional inserts.
Here’s a tip: use small dividers or boxes to section off the drawers, so nothing gets lost and it stays easy to keep track of things.
Good luck and have fun decorating!
bramfa schrieb:
I’m particularly interested in how to use the drawers and compartments most efficiently
It is worthwhile to take a critical view when using Brimnes, especially regarding its durability.
The construction is solid for the price, but weaknesses become apparent with frequent rearrangement or heavy use of the drawers.
That is a good idea, but you should pay attention to the original fittings, as standard solutions sometimes do not fit optimally and can affect stability.
Regarding efficiency: Dividing with partitions can improve organization, but I wonder if it sometimes adds more effort instead. Similarly, the idea of hooks on the doors is interesting, but I would like to know how much weight the hangers can support without damaging the structure.
Do you have experience or reliable data on this?
Furthermore, the question of optimal space utilization seems especially important for small apartments. While Brimnes allows for modular filling of spaces, the downside could be relying on fixed widths, which becomes problematic in irregularly shaped rooms.
TARAON schrieb:
You can unscrew the drawers and customize them further with shelving systems or additional inserts
Regarding everyday usability and storage capacity of Ikea Brimnes, I can provide the following precise information:
- The drawers come standard with shelves inside, which can be removed to accommodate taller items.
- To optimize the internal layout, I recommend using modular plastic boxes or drawer dividers, which create clear organization and improve access to small parts.
- The furniture construction complies with DIN standards for residential furniture and is designed for a service life of at least 5 years, as long as there is no extraordinary strain.
- Caution during assembly: using the original screws and following the assembly instructions carefully is crucial for stability.
- The drawer volume is approximately 30% larger than comparable models from other manufacturers, which is an advantage for space organization.
Regarding space efficiency: yes, the dimensions are standardized, so it is important to measure carefully before purchase. However, there are flexible combinations of 2- and 3-door cabinets that offer different widths.
Important to know: Brimnes is not designed for excessive loads such as additional countertops or heavy equipment, so it is best to stick to traditional usage.
If there are specific requirements, such as installation in very small niches, custom modifications might be worthwhile, but in those cases, other solutions are usually more efficient.
Hector schrieb:
Brimnes allows modular filling of rooms, but the downside could be that you are dependent on fixed widths, which can be problematic in irregularly shaped rooms.
