ᐅ What tips are there for transporting IKEA BRIMNES through narrow staircases?
Created on: 22 Dec 2017 14:37
CaiofuHello everyone,
I am facing the challenge of moving an IKEA Brimnes piece of furniture through a very narrow stairwell, which also has tight turns. The doors to the stairwell are standard size, but the steps are narrow and the handrail is somewhat bulky. I've been considering whether to disassemble the item or move it fully assembled, but the furniture is quite large and delicate.
Are there any tips for transporting the BRIMNES as safely and efficiently as possible through such tight stairwells? Are there useful tools or aids I should be aware of? What are your experiences with moving IKEA furniture of this type and size through narrow stairwells?
I would really appreciate detailed, practical advice, as I want to get the furniture to the top floor with minimal damage and stress.
Patricknon22 Dec 2017 15:02Hello Caiofu,
When transporting BRIMNES furniture through narrow staircases, preparation is key. Here are some proven tips:
- Disassemble components beforehand as much as possible to reduce volume.
- Have packaging and padding materials ready, such as blankets or foam cushions, to prevent scratches on the furniture and walls.
- Measure the transport vehicle or route in advance, as well as all intermediate floors and door openings.
- For carrying, at least two strong people are recommended, with carrying straps if needed for better load distribution.
- Tilt and angle the furniture parts to maneuver them through tight corners.
Tools like ratchets or screwdrivers are helpful for quickly loosening parts. If you have such a toolset, a full disassembly is advisable. If you have any further questions, I’m happy to assist.
Hello Caiofu,
I would like to build on the very good answer from Patricknon and add some technical details that are especially relevant for IKEA BRIMNES furniture, as these pieces often use particleboard and metal fittings.
1. Before transport, check that all screws are tightened. Loose parts can come undone during transport and cause damage.
2. If disassembly is possible: always keep screws securely in a separate bag and attach it to the furniture to prevent any loss.
3. The individual components are easier to maneuver through narrow staircases if they are kept as flat as possible and carried stably.
4. When working in the stairwell, maintain maximum distance from the walls, ideally using soft padding on the furniture edges.
5. Check the load capacity of the staircase: especially older staircases can be strained by heavy furniture parts.
6. Use carrying straps: they relieve strain on the back and help control the furniture while carrying.
Could you possibly provide the dimensions of the stairwell and door opening? Then I can give you more targeted advice.
Patricknon schrieb:
Disassemble components beforehand as much as possible to reduce the volume.This is the most important point. Plus use blankets or padding for protection.
PIN66 schrieb:
Use carrying straps: They relieve the back and help control the furniture while carrying.I can only agree. Carrying straps make handling easier.
Also: always take corners slowly and carefully, better to spend more time than to rush.
Hello Caiofu,
I wanted to add some thoughts on the emotional and organizational aspects: tight moves can quickly become stressful if you’re not prepared. My advice is to not only check the dimensions and tools but also to plan for enough breaks and helpers.
The following points helped me:
- Secure everything well beforehand, for example by protecting floors and using railing pads to avoid damage.
- If possible, transport furniture parts in smaller sections, even if that means assembly takes longer.
- Organize communication with your helpers carefully. When everyone knows who does what and when, the process goes more smoothly.
Additionally, I had good experiences using sliding mats during my BRIMNES transport – they help slide the furniture through stairwells without creating much friction. This can be especially useful on wood surfaces.
Good luck with the move!
