I recently purchased two Ikea PAX wardrobe systems and am now facing the challenge of perfectly aligning the PAX doors. I noticed that, despite following the instructions carefully, the doors sometimes do not close properly or hang slightly crooked.
Therefore, my specific question is: What tips and methods are there to precisely and permanently adjust the Ikea PAX doors so that they close cleanly and are visually perfectly aligned? I am also interested in any tricks regarding the hinges, door gaps, and possible additional tools to make this alignment as simple and reliable as possible.
I appreciate advice of all experience levels—whether standard adjustments or custom modifications—to ensure the doors remain stable over time.
As a general recommendation, first carefully align all cabinet components on a flat surface before attaching the doors.
The PAX hinges offer several adjustment options: horizontal, vertical, and depth. Each of these should be adjusted step by step.
- Start with the depth adjustment to align the door flush with the cabinet frame.
- Then proceed with the horizontal adjustment to keep the gap between the doors even.
- Finally, adjust the vertical position to set the door height.
It is important that the doors remain freely movable before fully tightening the screws, allowing for fine adjustments.
If the cabinet frame is not perfectly level, it is advisable to compensate for unevenness by placing small shims underneath (e.g., felt pads or thin wooden pieces).
Patience pays off in general: repeated fine-tuning is normal until everything fits perfectly.
Ryker66 schrieb:
Adjust the door depth or height using the vertical screw in the hinge.That is correct. The three adjustment options of the PAX door hinges allow for precise fine-tuning:
- Vertical screw: adjusts the height of the door relative to the cabinet.
- Horizontal screw: shifts the door sideways.
- Depth screw: controls the door’s opening or closing depth.
When making adjustments, it’s best to work in small increments to avoid excessive repeated corrections. I also recommend closing the door after each screw adjustment to test how the gap and closing behavior change.
Additionally, keep in mind that uneven floors or inaccurate cabinet installation can significantly affect door alignment. Once properly aligned, all screws should be tightened to prevent further movement.
A practical tip: using a small spirit level strip or bubble level can help align the cabinet and doors precisely. It is also possible to compensate for minimal pressure differences inside the hinges with thin rubber buffers.
