ᐅ What are some tips for tidy cable management inside Ikea Besta furniture?
Created on: 28 Jul 2024 14:27
O
onlelenHello everyone,
Over the past few weeks, I have been looking into how to achieve clean and organized cable management when using Ikea Besta furniture. The Besta series is really flexible, but when it comes to wiring TVs, AV receivers, gaming consoles, and other devices, there is often quite a mess of cables—both visible and inside the furniture.
I am especially interested in practical tips for neat cable routing that is not only visually appealing but also functional. Topics like cable ties, cable ducts, modified back panels, or special cable grommets are of particular interest to me.
For example, do you have experience with installing cable grommets or special clips that can be attached to the back panel? And how do you generally handle sizing and sorting cables so that everything looks tidy but future changes can be made without much effort?
Thanks in advance for your advice!
For achieving clean cable management in Ikea Besta furniture, I recommend the following approach based on experience:
- Use cable channels with self-adhesive backing that can be attached to the inside of the back panels. This keeps cables securely fixed and better organized.
- Install holes in the back or side panels with rubber grommets to neatly guide cables and protect them from abrasion.
- Label cables with small cable tags or colored clips to maintain clarity.
- Group cables by device type (e.g., power, audio, video) to prevent tangling.
- Use reusable hook-and-loop cable ties, as they offer more flexibility for repositioning or system changes compared to traditional cable ties.
In addition, ensure sufficient airflow to prevent device overheating. Ultimately, a combination of these measures often works best.
This way, not only is organization maintained, but the durability of cables and devices is also enhanced.
tra_nina schrieb:
For creating clean cable management in Ikea Besta furniture, I recommend the following approach based on experience:This is a very good method. I would like to add to it and go into more detail regarding the practical work involved:
First, before assembling the furniture, you should carefully plan which devices will be connected and what types of connections are needed. Especially with Besta furniture, it is useful to prepare the back panel or inner back panels with properly drilled holes for cable pass-throughs. For the common materials used (mostly MDF or particleboard), high-quality hole saws with rubber rings are recommended, as they create clean openings and protect the cables.
Furthermore, I suggest not fully mounting the back panel if possible. Instead, create larger cutouts or frames to allow easy cable routing during device installation and future maintenance.
For organizing the cables: plastic or even metal cable ducts are ideal, especially when mounted on the back or inside rear panel of the furniture. These ensure neat cable runs and prevent tangling. Additionally, securing the cables firmly with hook-and-loop straps or cable clips is essential. When routing the cables, make sure they have sufficient length and are logically distributed to avoid tension on the connectors.
Last but not least, access to the connections is important. Typically, openings in the furniture should be planned so that devices can be easily swapped, cables reconnected, or extended without difficulty.
Do you or anyone else here have specific dimensions or experience with particular IKEA cable management accessories? I would be interested in that.
onlelen schrieb:
Have you, for example, already had experience with installing cable entries or with special clips that can be attached to the back panel?Yes. You can easily install cable entries using hole saws; rubber grommets protect the cables. Plastic clips with screw fasteners hold well, especially if you remove the back panel and mount them on the inside of the furniture.
To complement the previous tips, I have put together a brief step-by-step tutorial for neat cable management in Ikea Besta furniture:
1. Planning
- Determine all cables to be routed, including their lengths.
- Check the device connections and their positions within the furniture.
2. Preparation
- Remove the back panel during assembly to gain access.
- Mark the locations for cable entry points.
3. Creating the entries
- Carefully drill holes with an appropriate hole saw, ideally slightly larger than the cable diameter.
- Install rubber grommets to prevent cable abrasion.
4. Routing
- Route power cables separately from signal and data cables to minimize interference.
- Use hook-and-loop cable ties for secure bundles that remain easy to maintain.
- Attach these bundles with sufficient spacing to cable ducts or clips.
5. Completion
- Reattach the back panel including the designated cable entries.
- Check all cable connections before powering up the devices.
Common mistakes to avoid:
- Planning too little cable length, which leads to cramped spaces.
- Not securing cables, causing them to tangle when moving the furniture.
- Using overly rigid cable channels that do not conform well to shapes.
If you like, I can also share tips on which hook-and-loop straps and cable clips I personally prefer.
1. Planning
2. Preparation
4. Routing
5. Completion
