ᐅ What tips are there for assembling Ikea HEMNES furniture without assistance?
Created on: 9 Jul 2018 07:42
ChenrobbieC
Chenrobbie9 Jul 2018 07:42Good morning everyone, I’m planning to get the Ikea Hemnes shelving unit and wanted to ask: What tips do you have for assembling this piece of furniture completely on your own? I have some DIY skills but no helper available, and the unit seems quite bulky and heavy. I’m also interested in efficient methods and tricks to handle unpacking the boxes, managing individual parts, and screwing everything together without risking mistakes afterwards. Which tools would you definitely recommend? I appreciate any practical advice!
I’m happy to provide you with a simple step-by-step guide for assembling the HEMNES shelf solo: - First, sort all the parts and check the instruction manual to make sure everything is included. - Organize all screws and wooden dowels neatly in small containers. - For handling large wooden parts, use a soft, non-slip surface like a rug or carpet scraps to prevent damage. - Always complete one section fully before moving on to the next part. - Important: Use a cordless drill with adjustable torque to avoid over-tightening the screws. - When aligning the shelves, use a spirit level to ensure everything is straight in the end. - Common mistake: confusing parts – measure carefully. Good luck!
Hey, I assembled the HEMNES on my own and I can only say: don’t forget to breathe! 😅 Seriously, take your time and follow the steps one by one. Play some music or a podcast to keep your spirits up. Also, a little thread lubricant or some soap on the screws can sometimes make tightening easier. Otherwise, you’ll quickly end up with a sore arm. Good luck!
Hello Chenrobbie, I’m happy to help you! The key is good time management: if you’re building on your own, make sure to allow enough time and breaks. It is important to have stable and as level as possible surfaces so nothing wobbles. When assembling the HEMNES, it helps to first connect the side panels on the floor, then insert the shelves. You can also temporarily support large parts with objects. A tip for handling: - Always lift large parts close to your body and avoid twisting motions to protect your back. - If you are using a cordless drill, check the battery charge beforehand and use the correct bit to avoid damage. Feel free to ask if you have any questions!
