ᐅ What surface modifications are possible with Ikea Hemnes?
Created on: 17 Sep 2024 18:22
fravolker
I am currently exploring the possibilities for surface modifications on the furniture from the Ikea Hemnes series. I am less interested in complete rebuilds or self-made structural changes and more focused on options that primarily affect the surface—such as painting, staining, wallpapering, or applying vinyl wraps. Based on your experience, what options are available? Which methods have proven effective, and what specific considerations should be taken into account regarding materials and application to ensure the surface remains durable and visually appealing over time? Additionally, I would like to know how well the original finishes of the Hemnes models respond to these treatments, and whether they facilitate or complicate the application of other materials. I look forward to your practical tips and as detailed an assessment as possible!
Jensson
18 Sep 2024 10:44
I would like to add a brief guide on how to superficially modify a Hemnes tabletop, for example, to achieve greater durability and an attractive appearance:
1. Thoroughly clean and degrease the surface
2. Lightly sand the surface with 180-grit sandpaper, removing old varnish residues but without sanding too deeply into the wood
3. Remove dust, ideally wipe with a damp cloth, and let dry
4. Apply a primer (bonding primer or wood primer) and allow it to dry well
5. Apply two coats of varnish (water-based for a natural look or acrylic varnish for higher durability)
6. Lightly sand between coats with 320-grit sandpaper to create a smooth surface
For veneers or laminates, please note that these steps are even more important to ensure good adhesion. Also, avoid direct sunlight and high humidity.
ju_ren
18 Sep 2024 11:36
One more tip: Use a cloth to apply the stain evenly. Afterwards, seal it with a clear varnish. This way, you achieve a preserved wood look and protect the surface against scratches.
SETHBLA
18 Sep 2024 12:04
Additionally: For those looking for a quick change, furniture wax can be an option. It protects the surface, highlights the wood grain, and is easy to apply and polish. However, its protective effect is less durable compared to varnish.
