ᐅ What surface modifications are possible with Ikea Hemnes?
Created on: 17 Sep 2024 18:22
fravolker
fravolker
17 Sep 2024 18:22
I am currently exploring the possibilities for surface modifications on the furniture from the Ikea Hemnes series. I am less interested in complete rebuilds or self-made structural changes and more focused on options that primarily affect the surface—such as painting, staining, wallpapering, or applying vinyl wraps. Based on your experience, what options are available? Which methods have proven effective, and what specific considerations should be taken into account regarding materials and application to ensure the surface remains durable and visually appealing over time? Additionally, I would like to know how well the original finishes of the Hemnes models respond to these treatments, and whether they facilitate or complicate the application of other materials. I look forward to your practical tips and as detailed an assessment as possible!
Paunon
17 Sep 2024 18:48
Basically, Hemnes furniture can be easily sanded and repainted since it is usually made of solid wood. I would avoid using foils as they do not adhere well. For a longer-lasting finish, I recommend using pure paints or wood oil.
Lorukeo
17 Sep 2024 19:05
Hemnes is mainly made of pine wood, which has the advantage of a relatively durable surface that also sands well. This makes painting and staining easier. The following options are common:
- Sanding and painting (beware of excessive sanding, as the veneer can be thin)
- Staining to highlight the wood grain
- Applying high-quality self-adhesive films, although these adhere better to smooth, non-porous surfaces
- Painting with chalk paint, then sealing for a matte finish
It is important with all methods to thoroughly remove dust from the surface before working and, if necessary, to apply a primer. Water-based paints usually achieve a very natural and long-lasting result.
likuken
17 Sep 2024 19:34
What I often notice about the Hemnes series is that it is always described as “solid wood,” but people forget that there is also paint or clear lacquer on the surface. Many underestimate how much this surface treatment influences the appearance and craftsmanship.
Paunon schrieb:
I would avoid veneers because they don’t adhere well.
I see it differently. Sure, veneers don’t last forever, but with a bit of effort, proper surface preparation, and the right choice of veneer, you can achieve really good surface transformations. Even if it’s only temporary, you can quickly change the style without damaging the wood.
Anyone who thinks that only paint or stain are the options is mistaken in my opinion. Veneers are quite popular in the interior design scene and are used creatively – even with Hemnes.
gregto
17 Sep 2024 20:17
I think it’s good that several options have already been mentioned here. To provide a more comprehensive overview: Hemnes, due to its rather traditional pine wood and surface treatment, is quite adaptable.
- Sanding and repainting is the classic method, especially recommended for scratches or color changes.
- Staining is a surface finishing technique that highlights the wood while adding color, which can look very attractive depending on your preference.
- Self-adhesive films can be applied easily with proper preparation, which includes cleaning the surface with alcohol and lightly sanding it beforehand.
- Chalk paints offer the possibility of achieving a matte, vintage look but should be sealed afterwards with wax or varnish.
It is important with all methods to ensure the surface is made smooth and allowed to dry thoroughly so it can withstand wear and tear. A small test on an inconspicuous spot can help avoid disappointments later on.
INGRID34
18 Sep 2024 09:12
A quick note on stability: Hemnes makes applying films difficult due to its slightly porous surface. I definitely recommend sanding beforehand and applying a smooth primer. This is the only way to ensure the film adheres for a longer time.
