ᐅ What steps are necessary to achieve a Q3 finish from a Q2 interior plaster?
Created on: 18 Nov 2016 20:33
tecker2010Hi,
The general contractor will hand over the house with Q2 interior plaster. We plan to mainly do the painting ourselves or hire painters for it. Having the whole house painted professionally is quite expensive, so we are considering doing some of the walls on our own. We will have all the ceilings done by professionals because we want to install painting fleece there. The main question is: What exactly is required to bring a Q2 wall to Q3 level so that dispersion paint can be applied directly?
From what I have researched so far, at the very least, all walls should be sanded with a float or sanding block. However, this probably is not enough, and all walls would need an additional layer of gypsum-based finish plaster, such as a bonding plaster like Knauf Rotband (which I have read about frequently). Is this correct, or what do the experts here recommend?
Bauexperte18 Nov 2016 23:45tecker2010 schrieb:
We will have all the ceilings done because we are also having painter's fleece applied here.Not a bad decision; fiber fleece is not so easy to handle.tecker2010 schrieb:
The real question: What exactly is needed to upgrade a Q2 wall to Q3 so that dispersion paint can be applied directly afterward?A sufficiently thick base coat plaster and several sanding steps.Regards, Bauexperte
