ᐅ What types of special handles are available for IKEA PLATSA doors?
Created on: 11 Jul 2023 14:37
AlessioHello everyone, I am planning to upgrade my IKEA Platsa cabinet doors and came across the question of which specific handles are actually available for these doors. Since Platsa differs somewhat from the usual IKEA furniture due to its modular design and the various door sizes, I am unsure whether the standard handles from other series fit here or if there are special solutions that work particularly well. I am therefore especially interested in:
- Which types of handles (e.g., handle strips, bow handles, recessed handles) are compatible with Platsa?
- Are there special handle models from IKEA or third-party suppliers that are specifically designed for the material thickness and mounting on Platsa doors?
- Experiences regarding the installation, durability, and appearance of handles on Platsa doors would also be very helpful.
I look forward to tips and recommendations from those of you who may have already tried solutions, and I imagine this topic is of interest to many who want to customize the Platsa system.
Hello Alessio, your question is very well formulated, so I’ll provide a brief overview of special handles for IKEA PLATSA doors.
1. IKEA Standard Handles and PLATSA: Unlike many other IKEA cabinet doors, PLATSA doors have a slightly different material thickness and mounting options. Therefore, not all standard handles from series like METOD or PAX fit without adjustments.
2. Recessed Handles (Flush-Mounted): With PLATSA, recessing handle strips or grip grooves is often possible because the doors usually offer sufficient thickness for a groove. However, IKEA does not offer dedicated handle strips specifically for PLATSA, making it useful to purchase from third-party suppliers.
3. Handle Strips and Pull Handles: These can definitely be installed if the screw length is appropriate and the doors are not damaged. It is essential to check the door thickness before purchasing and, if necessary, use screws that do not penetrate all the way through to the interior.
4. Installation and Tips: To avoid purchasing mistakes, I recommend precisely measuring the hole distances and door thickness beforehand. Some users even drill additional holes themselves or use adhesive-backed handles, especially on fronts made of plastic or coated particleboard.
Summary:
- IKEA does not sell specific handles for PLATSA but offers universal handles that can fit (pay attention to screw length)
- Third-party suppliers offer handle strip-like solutions, for example made of aluminum
- Recessed handles are a good option for a neat design but may be more complex to install
Hope this helps with your planning!
Summary:
Alessio schrieb:
I am especially interested in: - Which types of handles (e.g., handle strips, bar handles, recessed handles) are compatible with PLATSA?I can share something casual right away: Basically, a lot of handle types work with PLATSA as long as you pay attention to the door thickness. I personally installed simple handle strips from third-party suppliers, which are super easy to fit and give your PLATSA a small upgrade without much drilling.
Alessio schrieb:
Experiences regarding the installation, durability, and appearance of handles on PLATSA doors would also be very helpful.Briefly from my perspective: The durability is excellent, at least if you use proper screws. Appearance? Really nice, especially if you prefer clean, minimalist handles. A small tip: Matte black or aluminum handle strips usually match very well with the different PLATSA colors. It can make your cabinet almost feel like a designer piece 😉
Hello Alessio, I find your inquiry really interesting because the topic of handles for PLATSA is not straightforward, and many people underestimate how much the details matter. Let me explain in detail:
- Material thickness: PLATSA doors are made from MDF or particleboard with a thickness of usually about 16 mm (0.63 inches). This often does not match the standards of other IKEA series, which means common handles don’t always fit easily. The screw length is crucial here, as screws that are too long can go through the door and cause damage.
- Mounting points: Some PLATSA doors only have pre-drilled holes for hinges and no holes for handles. If you want to install pull handles, you either have to drill precise holes yourself or opt for models that can be attached with adhesive strips or magnetic mounts. This can vary significantly depending on the type of handle.
- Common handle types:
- Handle bars (aluminum or stainless steel): Very popular, especially on narrow doors. Advantage: flush and modern look, but installation requires exact drilling.
- Recessed handles with groove: Not directly from IKEA, but third-party suppliers offer profiles that can be inset into the edge, which looks very attractive. However, routing work here is somewhat demanding.
- Pull handles: The simplest solution, as long as the screw length fits. I recommend shortening IKEA screws to a maximum of 12 mm (0.47 inches) or purchasing suitable ones.
- Installation tips: For all handles, you should definitely check the installation measurements on the door or cabinet frame before assembly, and verify the mounting method once again. It sounds complicated but is worth it, as incorrect installation often damages the surface.
What style are you planning specifically? Does this overview help, or should I share specific product recommendations or manufacturers?
Nakar33 schrieb:
What specific style do you want to achieve? Does the overview help you, or should I provide more specific product recommendations or manufacturers?I find this question very important – because people often underestimate how much the choice of handle affects the overall atmosphere of the room. Alessio, if you want to use your PLATSA in a more classic or Scandinavian style, subtle handle strips or recessed handles might be the perfect choice.
If you prefer to keep the doors modern and minimalist, the trend is often toward handleless solutions or push-to-open systems, which create a very clean, uncluttered look. Have you considered these kinds of systems? They sometimes reduce ease of use a bit, but in return, you eliminate visible handles, which looks extremely sleek.
I encourage you to experiment consciously with handles. The selection is larger than most realize, and there is something suitable for almost every preference.
