ᐅ What special considerations are there when assembling Ikea Brimnes dressers?
Created on: 5 Apr 2017 17:43
Coskun49
I recently purchased an Ikea Brimnes dresser and noticed that its assembly has some unique characteristics compared to other Ikea furniture.
I am particularly interested in any structural or craftsmanship details during the assembly of Brimnes dressers that should be considered to ensure the most stable and secure installation.
Are there specific joining techniques, assembly steps requiring special care, or differences in materials?
Any advice on handling the drawers and rollers would also be appreciated.
I look forward to your experiences and tips!
Joshbe
7 Apr 2017 12:29
In summary, I would like to highlight the key features when assembling the Ikea Brimnes dressers:
- Central partition as a main support: It should be aligned precisely to ensure the dresser’s stability.
- Drawer system: The plastic roller glides require careful insertion of the drawers. Inserting them at an angle or with too much force can damage the system.
- Back panel installation: To facilitate assembly, it should be attached last, as it stabilizes the dresser against warping.
- Connection method: Dowel and cam lock fittings between the side panels and top/bottom panels help ensure correct positioning before screwing.
- Screws and dowels: Avoid overtightening to prevent material damage.
If these points are followed, assembling the Brimnes dressers is straightforward and the furniture remains stable.
U
Ulrichta
7 Apr 2017 20:51
Coskun49 schrieb:
Is there a trick to perfectly insert the drawers into the runners without them getting stuck or misaligned?
Yes, I’m happy to help.
My advice is to stay patient and calm, and use both hands: with one hand, gently lift the drawer from below, while guiding it along the runner with the other hand. Usually, the drawer sticks because the rollers aren’t sitting exactly on the track or because the drawer is inserted at a slight angle.
I recommend checking the runners carefully before inserting the drawers and adjusting them slightly if needed.
The order of assembly can also help. This is how I usually do it:
- Insert and secure the center panel first
- Check that the runners move smoothly and are properly aligned
- Insert the drawers, keeping them parallel and pushing in gently
- Adjust if necessary before attaching the back panel
Don’t worry, it works quite well with the Brimnes if you take your time.
