ᐅ What special considerations are there when assembling Ikea Brimnes dressers?
Created on: 5 Apr 2017 17:43
Coskun49
Coskun49
5 Apr 2017 17:43
I recently purchased an Ikea Brimnes dresser and noticed that its assembly has some unique characteristics compared to other Ikea furniture.
I am particularly interested in any structural or craftsmanship details during the assembly of Brimnes dressers that should be considered to ensure the most stable and secure installation.
Are there specific joining techniques, assembly steps requiring special care, or differences in materials?
Any advice on handling the drawers and rollers would also be appreciated.
I look forward to your experiences and tips!
Kabau
5 Apr 2017 18:12
The Brimnes dressers often feature a central partition that must be correctly aligned during assembly, as it significantly enhances stability.
Additionally, the drawers are equipped with a click system – make sure the drawer slides are properly engaged.
Other than that, there are no major special features.
pauPierce
5 Apr 2017 19:37
Regarding the specifics of assembling the Ikea Brimnes dresser, I would like to explain some details in depth:
- First, the dresser is made of coated engineered wood, which requires careful handling during screwing. The screws should not be tightened too much to avoid cracking.
- The key feature is the angled frame and the central panel, which is either glued or slotted into the groove. This central panel significantly contributes to the overall stability, so correct alignment here is critical.
- The drawers run on plastic-coated rollers. These must be positioned precisely on the rails to ensure the drawers operate smoothly without sticking.
- Another point is the back panel: it is a thin fixing board attached with pins and serves to stabilize against lateral movements later on, but it should not be fixed too early during assembly, as this would complicate adjustments when inserting the drawers.
- It is also important to use the supplied dowels correctly: they are designed for an exact drill size, and undersizing can lead to fitting problems or instability.
Could you specify at which assembly step you felt uncertain? Then I can provide more targeted assistance.
Coskun49
5 Apr 2017 20:04
pauPierce schrieb:
Can you specify exactly which assembly step you were unsure about? That way I can provide more targeted help.
Thank you for the detailed information! I found the comments about the partition wall and the back panel especially helpful.
My uncertainty is about inserting the drawers and aligning them correctly on the runner slides.
Is there a trick to perfectly fit the drawers onto the runner slides without them getting stuck or misaligned?
Also, is it better to install the back panel before or after inserting the drawers?
giabau
6 Apr 2017 08:17
I am happy to provide a brief step-by-step guide for inserting the drawers in the Brimnes chest of drawers:
- Step 1: Make sure that all the rollers in the drawers are properly seated and can rotate freely. Possible manufacturing tolerances may cause issues here.
- Step 2: Insert the drawers as parallel to the chest as possible, not at an angle from above.
- Step 3: First position the front rollers on the rail, then gently and evenly push the drawer backward to engage the rear rollers.
- Step 4: If the drawer sticks, try pulling it out completely and adjusting it slightly at different angles. A bit of patience is important here.
Regarding the back panel: It is best to attach the back panel only after all the drawers have been inserted, as attaching it beforehand makes sliding in the drawers more difficult and reduces some room for adjustment.
In summary: Inserting the drawers requires a delicate touch, and the back panel secures the entire structure finally.
chenlen
6 Apr 2017 09:44
In addition to the previous post:
A special feature of the Brimnes dressers is the type of connection between the top and side panels. A precisely fitting connector is often used here, which can be easily snapped together with a simple spring mechanism and provides additional stability.
This connector should be fixed in place before screwing, otherwise the geometry will not be properly maintained.
Furthermore, the assembly instructions for Brimnes can be somewhat unclear for some, so I recommend first loosely fitting all connections together without applying pressure before screwing them in place. This way, it becomes easy to spot if something is incorrectly positioned or needs adjustment.
