ᐅ What replacement parts are available for Ikea PAX closet doors?
Created on: 10 Aug 2024 18:23
Bavin1
Bavin1
10 Aug 2024 18:23
Hello everyone, I am looking for a comprehensive overview of which spare parts are available for Ikea Pax doors. Specifically, I am interested in the typical wear parts or components that usually need to be replaced after long-term use – such as hinges, handles, runners, or locks. It would also be helpful to know whether these spare parts are offered directly by Ikea or if there are recommended third-party suppliers that provide products of comparable or even better quality. Additionally, I would like to find out if there are differences in spare part availability depending on the door model (e.g., hinged doors vs. sliding doors) and whether these components can be easily replaced by oneself or if special tools or expertise are required. I look forward to your tips and experiences!
TEOZAR
10 Aug 2024 20:47
Hello Bavin1, thank you very much for the detailed question, it makes it easier to provide a targeted answer. Basically, Ikea itself offers a range of spare parts for the PAX doors, which can be ordered in most stores or through the online shop. These mainly include:
- Hinges and their covers
- Handles of various models
- Rollers and tracks for sliding doors
- Screws and fastening materials
- Door dampers (soft-close mechanisms)
For hinged doors, hinges and handles are the most commonly replaced parts, as hinges can loosen or wear out over time, and handles may become damaged or scratched.
For sliding doors, you should pay special attention to the rollers and their corresponding tracks, which can wear out and ensure smooth operation. Most spare parts are designed to be replaced using a simple screwdriver or an Allen key—special tools are usually not required.
Bavin1 schrieb:
ob es Unterschiede in der Ersatzteilverfügbarkeit je nach Türenmodell (z. B. Drehtüren vs. Schiebetüren) gibt
Yes, indeed. The range of spare parts for sliding doors is somewhat more specialized because the mechanism is more complex, while hinged doors generally use more standardized hinges. There are third-party suppliers, especially for handles, which are often more stylish or durable, but for mechanical parts like rollers, I would recommend sticking with the original.
If you like, I can also put together a list of the most important item numbers for you.
lyndon
11 Aug 2024 09:36
TEOZAR schrieb:
For hinged doors, hinges and handles are the most frequently replaced parts, as hinges can loosen or wear out over time, and handles may get damaged or scratched.
That sums it up very well. Additionally, it should be mentioned that for older PAX models, some replacement parts are no longer stocked by Ikea itself once the product line has been discontinued. In such cases, specialized Ikea spare parts dealers or platforms for used parts often provide a valuable alternative.
Furthermore, for sliding doors, important wear parts include the small plastic holders or stoppers that prevent the door from coming off the track. These are often overlooked but are essential for proper function.
I also recommend carefully reviewing the installation instructions before attempting to replace parts yourself, as there can be variations in component dimensions depending on the production year and model. When in doubt, photos of the door mechanism can be helpful when searching for replacement parts in specialist stores.
In general, PAX is modular in design, and replacement parts are mostly easy to exchange, which simplifies servicing in case of defects and allows for longer usage.
INGRID34
12 Aug 2024 11:51
Greetings!
Spare parts for PAX doors include:
- Hinges
- Handles
- Door dampers
- Fasteners
You can order original parts directly from Ikea. For older models, it can be more difficult as some parts may no longer be available.
Most parts can be replaced by yourself, usually just a screwdriver and an Allen key are needed.
