ᐅ What size adjustments are possible with IKEA PLATSA?
Created on: 28 Nov 2024 08:37
Santiagoma
Santiagoma
28 Nov 2024 08:37
Hello everyone, I am currently planning a new furnishing project with IKEA Platsa and have been considering the possible size adjustments that this system allows. I am particularly interested in which specific dimensional modifications can be made by yourself with IKEA Platsa, or which options IKEA offers as standard. Specifically, I mean whether individual modules can be adjusted in height, width, or depth, if there are special solutions for unusual ceiling heights, or if individual shelves can be positioned flexibly. Are there also known limitations, such as maximum load capacity for certain sizes or combinations? I would appreciate a as complete and accurate overview as possible so that I can optimize my planning.
sanjon
28 Nov 2024 09:12
Basically, the PLATSA modules have fixed widths and heights, but the depth varies between the different modules. You can place individual shelves flexibly, which is standard. However, IKEA does not offer custom sizes; you have to work with the given dimensions.
Kinbu
28 Nov 2024 10:05
Hello Santiagoma, I’m happy to explain this in more detail. With IKEA PLATSA, the basic modules come in standard widths and heights, usually in 60 cm (24 inches) widths and heights ranging from 64 cm to 240 cm (25 inches to 94 inches). The depth is generally either 35 cm or 60 cm (14 inches or 24 inches), which is clearly differentiated. The adjustable shelves inside the modules can be repositioned in fixed increments, allowing you to customize the interior layout.
Regarding adaptation to unusual ceiling heights, there are certain set heights, but often you can create a taller cabinet system by combining multiple modules. However, IKEA does not manufacture custom sizes—so if you need non-standard dimensions, retrofitting with custom-cut parts from external providers might be necessary.
Load capacity depends on the module type: cabinets with greater widths or heights should always be anchored to the wall to ensure stability.
KAULIS
28 Nov 2024 11:28
For clarification: The PLATSA series uses a standardized grid system with a width of 60 cm (24 inches) and heights ranging from 64 to 240 cm (25 to 94 inches). The depth options are either 35 or 60 cm (14 or 24 inches). Shelves can be positioned flexibly at intervals of approximately 3 cm (1 inch). Custom sizing in terms of variable depths or widths is not possible during purchase. For non-standard ceiling heights, IKEA offers individual extension modules, which are not available in unlimited sizes but come in fixed dimensions. Additionally, it is essential to pay attention to the load capacities: The weight limit of the shelves is usually between 10 and 15 kg (22 to 33 lbs). For larger units, wall mounting is mandatory to prevent tipping hazards. Those who do not use standard dimensions will need to rely on custom solutions outside of IKEA.
sanjon
28 Nov 2024 12:45
KAULIS schrieb:
A dimensional adjustment in terms of variable depths or widths during purchase is not possible.
Exactly, that cannot be changed. The system relies on modularity, not individual custom cuts.
Kinbu
29 Nov 2024 07:16
Santiagoma schrieb:
Are there also known limitations, such as maximum load capacity for certain dimensions or combinations?
This is an important point: The load capacity of the doors and shelves in PLATSA is well designed but always limited by the construction itself. The shelves support up to 15 kg (33 lbs), which is sufficient for clothing, books, or decorations. For heavier loads, special fittings and additional reinforcements are required – these are generally not offered by IKEA. Also, combinations taller than 240 cm (7 ft 10 in) or with significantly altered widths are possible, but stability should be ensured through wall mounting.
