ᐅ What should I keep in mind when assembling Ikea Hemnes desks?
Created on: 3 Oct 2020 08:17
Li_leopoldL
Li_leopold3 Oct 2020 08:17Hello everyone, I am currently planning to assemble an IKEA Hemnes desk and wanted to ask in advance: What should I specifically keep in mind when putting together the IKEA Hemnes desk to avoid common mistakes and ensure the best possible stability? Are there any particular considerations for assembling the individual components or recommendations for tools that prove especially useful? I want to make sure I don’t overlook anything, as I aim to set up the desk to be as durable and safe as possible. Does anyone also have tips for handling the larger parts or preparing for the assembly? Thanks in advance for detailed advice!
Hello Li_leopold,
there are indeed some important points to keep in mind when assembling the Hemnes desk to achieve the best possible result. First of all, I recommend doing the entire assembly in a tidy and, above all, clean environment. This prevents the hassle of searching for small screws and allows for more precise handling.
From my experience, the following aspects are essential:
- Start by identifying all parts according to the manual. Even if this seems tedious at first, it helps avoid mistakes during assembly later on. Check the wooden panels for any damage, as small scratches or defects can sometimes affect the overall stability.
- The provided screws and dowels are specifically designed for the wood joints. Be sure to use the included Allen key, or if you want to use a ratchet, choose one with a torque limit to prevent over-tightening.
- Precise alignment is especially important for the drawer slides and the side shelves. Make sure they are positioned parallel and at right angles.
- When attaching the tabletop, always start by tightening the screws only by hand. Then check the alignment once more before fully tightening them.
My advice: take your time and assemble in several stages, so you can pay closer attention to details. If you need support with specific steps, such as inserting the drawers or securing the back panel, just let me know. I can then provide more targeted help.
Li_leopold schrieb:
What should I pay attention to when assembling the Ikea Hemnes desk to avoid common mistakes and ensure the best possible stability?
JAMESONB413 Oct 2020 11:03Hi, the most important thing is to sort all the parts beforehand and follow the instructions step by step. First, screw in the screws loosely, then tighten them. Pay close attention to the alignment of the parts, especially the drawers. You only need the supplied hex key and possibly a screwdriver for the back panel.
reoleon474 Oct 2020 14:29Oh, the Hemnes desk is really a great piece! 😊 I recently assembled mine, and what can I say? If you follow Surela’s patient approach, everything goes smoothly. My tip: take your time and enjoy the process! I even noticed the second time around how to handle things better, for example when inserting the drawers, which are a bit tricky at first. So stick with it—it’s worth it, and in the end, you’ll have a nice piece of furniture that can even help out during rearranging if needed. Good luck and don’t stress!
Hello Li_leopold, I can only confirm Surela’s points – it is really important to proceed in a structured way and work carefully. In addition, I recommend checking all screws and parts for completeness before starting the assembly. Especially with larger furniture from IKEA, it can happen that some components are delivered with missing parts. If this happens, check your package immediately for replacements or contact customer service.
Also, when assembling the Hemnes desk, it’s helpful to have two people handle the heavier parts – this increases safety and makes precise alignment easier. The tabletop in particular can require some strength to secure.
For me, this is one of the most important steps I always follow. Have you already started the assembly, or are you still in the planning phase? Then we could focus more specifically on certain steps.
Surela schrieb:
When attaching the tabletop, you should always start by tightening the screws only by hand. Then double-check the alignment before fully tightening them.
