ᐅ What should I do if an IKEA PLATSA door is warped?
Created on: 22 Jan 2023 18:23
MAARTEMIS1
I have an issue with an IKEA Platsa door that has warped over time. Specifically, the door no longer closes properly and appears to be misaligned on one edge, so it functions but doesn’t close flush. Has anyone had experience with this and can suggest the best way to fix it? I have already tried adjusting the screws on the hinges, but that made little difference. Are there any special adjustment techniques or common mistakes during installation that can cause this kind of warping? I would appreciate concrete tips, as I want to restore the door myself with minimal effort.
Siflo
24 Jan 2023 08:52
In summary:
- Checking the frame for flatness and stability is essential.
- Fine-tuning the door via the hinges is the most important step.
- If the door is warped, it may have physically changed shape, which can only be partially corrected.
- In such cases, sometimes only replacing the door panel helps.
If you want to adjust the hinges precisely, work systematically:
1. Take the door off its hinges
2. Inspect and, if necessary, clean the hinges
3. Adjust each fine-tuning screw by millimeters and test again
4. Rehang the door and check
After adjustment, the door should not stick in multiple places or have excessive play. A careful check with a spirit level is helpful to fully identify any distortions in the furniture.
