ᐅ What should I do if the drawers of an Ikea Besta unit are not sliding properly?
Created on: 1 Jul 2024 08:37
Dafar
I recently purchased an Ikea Besta shelving system, and unfortunately, the drawers are not working as I expected. Specifically, the drawers slide very stiffly and catch at various points when opening and closing. This kind of malfunction is obviously inconvenient in daily use, and I would like to resolve the issue as efficiently as possible.
My question is: What can I do if the drawers of an Ikea Besta unit do not slide properly?
I have already checked whether they are correctly installed and if anything is obstructing them, but so far I haven’t been able to identify a clear cause. Are there common issues I should systematically check? Can the smoothness of the drawers be significantly improved by adjusting or lubricating, or is it better to replace individual parts? I look forward to your experiences and advice!
KLO-KA
2 Jul 2024 09:34
Check whether:
- the rails are parallel
- no screws are loose
- the tracks are clean
- silicone spray often helps
Otherwise, replace the rollers.
benon
2 Jul 2024 13:47
Hello Dafar,
I would like to revisit some options that you can quickly check yourself.
1. Thoroughly clean the running tracks: dust and debris often accumulate, causing friction.
2. Check whether the drawer fronts and cabinet connections are precisely aligned, as even small misalignments can cause problems.
3. Use a silicone-based lubricant, which is well suited to improve smooth operation.
4. If there are visible damages to the tracks or rollers, don’t hesitate to order the appropriate replacement parts from Ikea.
If problems persist after these steps, it would be helpful to have exact details about the model and installation. I can then provide more targeted assistance.
I hope you get your drawers working smoothly again soon!
Dilen
3 Jul 2024 10:17
vin_leo schrieb:
Most of the time, the issue is with the rail installation or the drawer not being properly aligned.
This is a key point that I agree with. Incorrect adjustment of the rail height or even a slight angle can affect the entire movement direction.
Joshbe schrieb:
Check if the drawer is sitting straight and correctly in the rails.
For this, I also recommend the following procedure: Completely remove the drawer and hold it horizontally. Then reinsert it into the rail with careful visual inspection and feel, positioning it precisely to the millimeter. If necessary, make small adjustments to the screws or position.
benon schrieb:
Use a silicone-based lubricant that is suitable for improving smoothness.
Here it is important to ensure that the lubricant is actually based on silicone or Teflon, since other oils can quickly attract dirt or cause sticking.
Finally, a thought: In older Besta systems, there were sometimes variations in the quality of the running mechanisms straight from the factory. If none of the measures help, I would specifically consider newer or compatible alternatives.
