ᐅ What should I do if my IKEA Brimnes doors do not close properly?
Created on: 3 Sep 2024 09:13
Knud44
Knud44
3 Sep 2024 09:13
Hello everyone, I have a problem with my IKEA Brimnes wardrobe doors: they don’t close properly when I push them shut. The doors are slightly misaligned, and it feels like the hinges are no longer precisely adjusted or maybe the fasteners have loosened. I have already checked the screws; some could be tightened slightly, but the problem remains.
I would be interested to know what systematic steps you would recommend to make the doors close flush and firmly again. What are common causes with Brimnes wardrobes? Do I need to replace the hinges completely, or are there adjustment options that are often overlooked?
A guide or step-by-step instructions would be very helpful, ideally with tips on possible mistakes during assembly or use that are quickly missed. Many thanks in advance for your expertise.
fredle
3 Sep 2024 09:47
Hello Knud44, I can understand that well, as the Brimnes doors do have some particular features in their hinge mechanism.
Here is a structured approach that often helps:
- First, completely loosen all screws on the hinges at the door frame and the cabinet, but do not remove them.
- Then carefully adjust the door: Often you can slightly move the door up or down to align it properly.
- After that, tighten the screws without changing the position.
- Check if the hinges are bent or damaged – replace them if necessary.
- A common mistake is overtightening the screws, which can distort the door.
Tip: Small installation errors, such as a slightly misaligned drill hole or a twisted hinge plate, can cause such problems. If you want, I can explain exactly how to properly adjust the hinges.
Does this help for now?
Filippo
3 Sep 2024 10:22
Hello Knud44, your description of the issue sounds exactly like common problems with IKEA Brimnes cabinets, which I have analyzed several times myself.
To optimize the closing of the doors, a multi-step process is recommended:
1. Check the hinges: Brimnes hinges usually consist of a simple chrome steel construction with two or three adjustment screws. You should carefully test each screw – a delicate touch is important here.
2. Vertical and horizontal adjustment: Using the screws, usually three directions of movement can be adjusted. Each screw has its function:
- The vertical screw on the hinge allows you to raise or lower the door.
- The horizontal screw moves the door closer to or further from the cabinet body.
- The depth screw controls the pressure applied when closing.
Incorrect settings can cause doors to hang or have gaps.
3. Check the mounting holes: If there is too much play, the intended hold may be lost, screws may loosen faster, or the door may not sit securely.
4. Material deformation: Since the Brimnes is often made of particleboard with a foil coating, external moisture can cause slight warping and negatively affect the fit.
5. I am also curious: Are the doors equally loose at the lower or upper mounting points? Are there mechanical interferences when closing – what do you specifically feel when closing the doors?
Please feel free to write back, and I can provide you with even more specific adjustment advice.
PeoDaniel
3 Sep 2024 11:08
Hello Knud44, I had a similar issue with my Brimnes wardrobe, so I’d like to help you by explaining some basics.
Brimnes wardrobes generally have standard hinges that can be secured not only with screws but also adjusted using so-called adjustment screws, which allow you to fine-tune the door in three dimensions.
When doors don’t close properly, it’s usually a combination of:
- screws that have loosened, or
- hinges that are not properly adjusted, and/or
- screw holes that have become worn out from overuse.
My advice: proceed step by step. Open the door, check the screws on the hinge for any looseness, and then try adjusting the adjustment screws. Often, small corrections can lead to significant improvements.
Also keep in mind that the door may be mounted on slightly different planes—take your time to check this carefully.
If all this seems too complicated, I can also explain how to fully remove and reinstall the hinges.
lyndon
3 Sep 2024 13:57
An important note: For Brimnes models, special attention should be paid to the depth of the fixing screws. The screws must not penetrate too deeply into the wood, as this can compromise stability.
Additionally, it is worth checking the types of screws used: IKEA uses specific wood or particleboard screws designed for use with the panels. Replacing them with incorrect screws can lead to fitting problems.
Finally, I recommend using a spirit level or angle measuring tool to measure the exact distances and alignment of the doors. This is the only way to ensure precise adjustment.
INGRID34
3 Sep 2024 17:29
First, check if the hinges are properly positioned and the screws are tight.
If that doesn’t help, carefully adjust the screws on the hinges to align the door.
Sometimes screws loosen due to frequent opening and closing, which is normal.
