ᐅ What should I do if Platsa screws break during assembly?
Created on: 19 Apr 2023 08:37
Z
zoltan
Z
zoltan
19 Apr 2023 08:37
Hello everyone, I am currently assembling my Ikea Platsa cabinet but encountering a problem: some of the screws break when being screwed in. The material does not seem very durable, and I have already tried applying appropriate pressure without success. My question is: what can I do if Ikea Platsa screws break during assembly? Are there suitable replacement screws from Ikea or other manufacturers? What is the best approach to avoid damaging the furniture? Also, I would appreciate any tips on how to prevent such screw breakage in the future, possibly using special tools or techniques. Thank you for your help!
V
vinpau
19 Apr 2023 10:05
Hey, that sounds really frustrating, but don’t worry, you’ll manage it! 😊 First of all: Are the screws breaking off that early when you start tightening them? With Platsa, this can sometimes happen due to the relatively soft material or if the screwdriver bit doesn’t fit the screw drive perfectly.
- I’d recommend using the correct Allen key or screwdriver and making sure it fits snugly and securely.
- If screws break, it’s definitely worth ordering the right replacement screws separately from Ikea.
- If needed, you can also look for screws of the exact same size (usually M4 or M5) at a hardware store or online, but be sure to get the correct material and thread type!
And if you don’t apply too much pressure with the drill, you reduce the risk of the screw breaking. Keep at it—you can do this! 💪
bupar
19 Apr 2023 15:48
vinpau schrieb:
I would recommend carefully using the right Allen key or screwdriver to ensure it fits cleanly and securely.
This is an important point. Screw breakage in Ikea Platsa units often occurs because the drive (usually Phillips or Allen) is not flush with the screw head or the wrong tool is used.
Additionally, it is important to check whether the pilot hole in the wood was drilled deep enough, as applying too much force when screwing can also cause the screw to break.
Regarding replacement screws: Ikea offers spare parts directly—you need to contact their customer service. Alternatively, metric screws size M4 with fine threading fit if the measurements exactly match the damaged screws.
For added mechanical security, a drop of wood glue in the joint hole is recommended if the screw no longer holds well. Then you can carefully insert a new screw with the correct length and thread.
Tevin
20 Apr 2023 09:22
zoltan schrieb:
What can I do if Ikea Platsa screws break during assembly?
In general, it is important to be patient when screwing in and avoid applying too much torque, as both the metal of the screws and the pre-drilled MDF material of the Platsa cabinet are relatively soft.
vinpau schrieb:
With Platsa, this sometimes happens due to the relatively soft material or if the screwdriver bit doesn’t fit the screw drive perfectly.
Exactly, using perfectly fitting tools is essential. If screws break, it’s worth requesting replacements from Ikea customer service, as they usually provide them without any issues. Otherwise, it is recommended to:
- Use replacement screws of the same size and thread type (M4, fine thread)
- If necessary, slightly ream the pilot holes with a fine drill bit to reduce stress
- Optionally, apply a small dab of wood glue to improve joint strength
In the long run, carefully pre-drilling in high-stress areas (if practical) helps prevent screw breakage. If you have further questions about tools or techniques, I’m happy to help.
