ᐅ What should I do if the screws break during the assembly of IKEA Hemnes furniture?
Created on: 21 Dec 2023 07:52
Elgelau
Elgelau
21 Dec 2023 07:52
Hello everyone, I am currently facing an issue assembling my IKEA Hemnes wardrobe and hope to get some helpful advice here in the forum. While tightening the screws provided by IKEA, I noticed that some of them get damaged – sometimes the heads break off or the threads are immediately stripped, so the screwdriver no longer grips. My question is: What is the best and most effective way to handle the IKEA Hemnes screws breaking during assembly?
I have already tried not applying too much torque, but the problem persists. I would be very interested to hear about your experiences with replacement parts or if there are special techniques to avoid this issue. Any tips on how to easily replace damaged screws or whether it’s advisable to contact IKEA directly would also be very helpful. Thanks in advance!
koduga
21 Dec 2023 10:43
Hello Elgelau,
I can really understand how frustrating it can be when screws break during assembly – I had a very similar experience a few months ago with one of my IKEA furniture pieces. It almost feels like facing the final boss, especially since the quality of the cheaper screws isn’t always the best.
Elgelau schrieb:
How can I specifically and effectively deal with IKEA Hemnes screws breaking during assembly?
In my case, I contacted IKEA directly and received a replacement pack of the correct screws without much hassle. I think that’s the first and easiest option if you don’t want to immediately look for your own spare screws. IKEA’s customer service is surprisingly accommodating and straightforward, at least in my experience.
If you haven’t tried it yet, I would also recommend using the right tools and, above all, a screwdriver with the correct bit profile. Sometimes the issue is less with the screws and more with the tools.
How heavy are the damaged screws, or is it always the same spot on the furniture where you have problems? Maybe we can dig a little deeper into the cause together.
klo61
21 Dec 2023 12:21
Hello Elgelau,
I would like to add to koduga’s comments by suggesting a structured approach that can help you deal with broken IKEA Hemnes screws.
- First, it is important to use the right tools: most IKEA screws require a Phillips screwdriver or a hex key of the correct size.
- If the screw head is damaged because the screwdriver did not fit properly, the risk of breaking increases significantly.
- If screws break during assembly, you should avoid forcing them back in with more pressure; instead, carefully remove them.
- Replacement screws can sometimes be ordered from IKEA. The customer service can assist you with your furniture’s serial number and confirm if replacement parts are available.
- If IKEA does not deliver replacements promptly, you could get suitable replacement screws at a hardware store—make sure they match the dimensions and type, and that the material is strong enough, typically galvanized steel.
- I recommend inserting the screws slowly and straight during reassembly, without applying too much force, and, if possible, pre-threading them by hand.
It also helps to check the drilled holes for damage beforehand, because if they are too tight, the screws can be compromised.
If you like, I can give you more tips on assembling the Hemnes furniture. They are solid pieces, but unfortunately the screws are often the weak point.
Domau0
22 Dec 2023 08:04
Hello Elgelau,
Elgelau schrieb:
How do I proceed specifically and effectively when IKEA Hemnes screws break during assembly?
I like to take a somewhat more technical approach to this, because especially with furniture like the Hemnes series, some details should be considered to improve assembly quality and prevent screw damage.
1. Check screw type and material: IKEA usually uses screws made of softer metals, which saves costs but can break easily under too much torque. So adjust the force when tightening accordingly.
2. Use the correct torque: If you have a cordless screwdriver with adjustable torque settings, set it to a lower level – often setting 2–3 out of 10 is enough.
3. Screw head: If the head is already damaged, replace the screw before the damage worsens. A damaged head is difficult to grip.
4. Working method: It’s best to initially insert all screws loosely, meaning tighten them just lightly. Only once everything is roughly in place should you fully tighten them.
5. Getting replacements: IKEA uses different screw types, but Hemnes mainly uses wood screws with cylindrical heads. If IKEA does not offer replacements, use steel screws with the same diameter (usually M4 or M5) and length.
6. Check threaded holes: Some holes may be permanently damaged after the first screwing. Applying a bit of wood glue can help stabilize the hole before inserting a new screw.
One request: How exactly do the screws get damaged — during the initial tightening or when retightening? And which tools are you using specifically? This information could help provide more precise advice.
Lotizar
23 Dec 2023 13:37
Hello Elgelau and all interested,
to complement the previous useful contributions, I would like to summarize the procedure for dealing with broken screws in IKEA Hemnes furniture in a clear and systematic way.
- Identify the cause: Usually, it is either a material defect in the screws or incorrect torque application, as already mentioned.
- Document the problem: If possible, take photos of the damaged screws and note the exact type of screw (dimensions, thread type).
- Request replacement parts from IKEA: This is usually the recommended approach. IKEA often provides replacement screws as a goodwill gesture if they are damaged during assembly. It is important to have the purchase receipt and furniture item number ready.
- Alternative: Obtain technical replacement screws with the same specifications. For IKEA Hemnes products, these are usually DIN 7981 cross recessed sheet metal screws made of galvanized steel with a diameter of 4 mm (0.16 inches) – verify this precisely.
- Caution when buying screws independently: Screws must not be too long or too short, and the hardness must be correct; otherwise, damage to the remaining furniture parts may occur.
- Assembly instructions: Use a suitable cross-head screwdriver and apply torque carefully by feel. Screw in slowly and straight, avoiding any tilting.
- For severe damage to the wood thread: Use wood glue or special repair kits to stabilize the fixing holes.
In short: Trying to get replacement screws through the official IKEA channel is often the simplest solution. Buying screws yourself is possible but carries risks if you do not have exact replacement specifications.
This rational, structured approach should resolve the issue permanently.
