ᐅ What should I consider when transporting the Ikea BRIMNES furniture?
Created on: 30 May 2020 18:37
cemalte
cemalte
30 May 2020 18:37
Hello everyone, I am planning to buy a piece of furniture from the Ikea Brimnes series and would like to know what to consider when transporting it. Specifically, I am interested in whether there are special precautions to protect the furniture during transport, if it can be transported while still packaged, or if disassembly beforehand is recommended. Since the Brimnes series includes different types of furniture (such as beds, dressers, and cabinets), it would also be helpful to know if there are differences in how these should be transported. I would appreciate any tips on proper handling, securing the load, and the best modes of transport if anyone has experience with this. Thanks in advance!
Wyatt
30 May 2020 19:03
Hello cemalte,
Regarding your question, “What should I consider when transporting Ikea BRIMNES furniture?” there are several important points to keep in mind, as this series includes fairly large pieces that can be delicate. I’ll go through them systematically:
- Packaging and Condition: Most BRIMNES items come well-packaged from Ikea, which protects them from scratches and moisture during transport. It’s important to keep the packaging as intact as possible and, if feasible, transport the items inside their boxes.
- Disassembly: For dressers and beds, it’s often better to partially disassemble them, especially if the furniture is already assembled or you’re transporting it yourself. Handling the parts separately is easier and reduces the risk of accidental damage. However, Ikea usually delivers furniture flat-packed, which is an advantage for transport.
- Load Securing: Since the pieces are often large and flat, it’s best to stand them upright and secure them with straps or tie-downs. If you’re using a vehicle with an open loading area or a station wagon, make sure the furniture cannot shift and that no sharp edges of the vehicle rub against the furniture.
- Transport Vehicle: Of course, a car with a large trunk opening is ideal, but for bigger items, a van or at least a roof rack with proper fastening is recommended.
- Protection from Scratches: When removing the furniture from the box, be sure to use protective film or blankets to avoid damage.
One question for you: Have you already purchased the furniture, or are you planning to pick it up yourself at the Ikea store? This will significantly affect the best approach.
Raymond
30 May 2020 19:57
Hello cemalte,
I would like to share some basic tips with you, especially if you have little experience with transporting furniture.
- As mentioned earlier, the BRIMNES series usually comes packed in pieces. It is important to handle the individual parts carefully, as the surfaces are quite prone to scratching.
- Make sure the vehicle is dry and clean to prevent moisture or heavy dirt from getting onto the furniture.
- When loading: always place the heavier parts on the bottom and the lighter ones on top to avoid shifting during transport.
- If you cannot transport the furniture in the original boxes, use blankets or bubble wrap, as even small impacts can damage the surfaces.
- If you remove any furniture carriers or hinges yourself, mark all parts to make reassembly easier.
I tend to be cautious with furniture transport because repairs can be very time-consuming. I hope this helps!
mesila
1 Jun 2020 09:41
Hello everyone, I would like to add that there are some differences in handling the BRIMNES series depending on the type of furniture.
1. Brimnes Beds: These bed frames consist of many individual parts and some intricate components. It is important to pack them carefully in boxes before transportation and to secure them against bending. Slatted bed bases should especially be packed separately.
2. Dressers and Wardrobes: Boxes offer good protection for this type of furniture. If you are picking up already assembled furniture, I recommend at least removing the larger doors to make transport and securing easier.
3. Transport and Securing: My tip is to store furniture upright in vehicles with enough space. Additional protection can be provided by blankets or foam corner protectors to prevent corners from bumping into each other and causing pressure marks during transit.
4. Summary and Common Mistakes:
- A frequent mistake is insufficient securing: loose parts can shift and cause damage.
- Missing protective measures like packing items in boxes or wrapping them in foil increase the risk of scratches and cracks.
Finally, a quick question:
How long is your transport distance? Sometimes shorter routes are a bit easier, but careful securing never hurts.
Wyatt
1 Jun 2020 10:14
mesila schrieb:
How long is your transport distance? Sometimes shorter distances are a bit easier, but extra careful securing never hurts.
Very good point. Especially on longer trips, you must secure all parts so that even strong braking or cornering maneuvers don’t cause shifting.
I would add that the vehicle floor should be as flat and clean as possible, since unevenness promotes movement. Also: always place heavier items on the bottom and lighter ones on top—that ensures stability and prevents packages from tipping over.
Another tip: some BRIMNES parts have delicate edges, such as veneered surfaces. Protect these edges by maintaining some air gap to walls or hard materials during loading. Rubber buffers between the cargo and the wall help.
If you like, I can also prepare a transport checklist for you.
liRaul49
2 Jun 2020 08:19
For transporting the Ikea BRIMNES parts:
- Always keep them in the box
- Secure with ratchet straps
- Do not place heavy objects on top
- Use protective covers during open transport
- It’s better to have someone help due to weight and size
This should minimize the risk of damage.
