ᐅ What should I consider when planning a PAX wardrobe wall?
Created on: 24 Dec 2021 08:23
tokin
tokin
24 Dec 2021 08:23
Hello everyone, I am currently planning a Pax wall unit for my bedroom and want to make sure I don’t overlook anything important. Therefore, my question is: What should I definitely keep in mind when planning a Pax wall to ensure the result is both functional and durable? I’m particularly interested in tips regarding the appropriate room height, anchoring, interior layout, as well as potential pitfalls during assembly or material selection. Maybe you also have advice on useful accessories or ideas for making the most of the storage space. Thanks in advance for your experiences and suggestions!
Laurence
24 Dec 2021 09:51
Hello tokin, that is a very good and focused question. When planning a PAX wall, you should especially pay attention to the following points:
- The room height is important because PAX closets come in different heights. Make sure to maximize the height without touching the ceiling to accommodate any unevenness.
- Wall mounting is essential for stability, especially if you place multiple units side by side. Ensure the back panel is firmly anchored to the wall.
- Plan the interior layout according to your personal needs: clothes rails, shelves, drawers, or baskets offer different benefits.
- Doors are also an important consideration: sliding doors save space, while hinged doors provide better accessibility.
If you include accessories such as shelves or interior lighting, you can use the storage space much more efficiently. During installation, careful alignment and securing are crucial to prevent any wobbling or misalignment. Hope this helps you so far!
keogla
24 Dec 2021 10:13
I would recommend measuring the space precisely beforehand and making sure the floor is level. It is best to assemble the modules according to the plan first and carefully check the wall behind the PAX to select suitable wall plugs and screws. Don’t forget to read the installation manual thoroughly.
AUSTINREN
24 Dec 2021 12:37
Laurence schrieb:
The ceiling height is important because PAX wardrobes come in different heights. Make sure to use the maximum height without touching the ceiling.
It is very important to adjust the PAX wardrobe to the room height to avoid unwanted gaps at the top. Also keep in mind that the wardrobe back panel is usually made of thin material, so the wall mounting must be secure.
Additionally, consider the loads to be supported, especially if heavy clothing or boxes will be stored. The adjustable feet should be properly set so that the entire unit stands firmly on the floor.
Regarding the interior layout: plan the position of the clothes rails to ensure there is enough space for long jackets or coats. Interior lighting, for example LED strips, can be added later to improve visibility.
Finally, an important point: always check whether the PAX unit can be attached as a whole to a load-bearing wall, especially when combining multiple modules to create a long wardrobe wall.
gojan7
24 Dec 2021 13:04
It is important that the modules are properly connected, not just placed next to each other. Also, pay attention to the correct depth so that the doors can fully open and nothing obstructs them.
tokin
25 Dec 2021 07:46
Thanks in advance to everyone for the quick and informative answers! One point that is still unclear to me: What is the best approach to planning the interior layout to make the most effective use of the available storage space? I have quite a variety of clothing – from long winter coats to small t-shirts, plus many pairs of shoes – should I consider certain basic rules for this? Are there any guidelines on how many hanging rods per meter (yard) are practical, or how to best integrate shoe compartments?
