ᐅ What should you do if Ikea PLATSA drawers are sticking?
Created on: 2 Jul 2024 09:17
ridipi
ridipi
2 Jul 2024 09:17
I have a problem with my Ikea Platsa drawers, which have suddenly started sticking in my new shelving unit and can no longer be opened or closed smoothly. The drawers no longer slide smoothly, and this issue affects several pieces of the same model.
I have already checked if the drawer slides are bent or if there is anything obstructing them, but everything looks fine visually. The fittings also seem to be installed correctly. Are there any known reasons why the Platsa drawers might get stuck? And what is the best way to restore smooth operation without having to completely disassemble the construction?
I would appreciate practical tips and suggestions!
flo-Theres
2 Jul 2024 10:03
The most common reasons why Ikea PLATSA drawers stick are usually the following:
- Improper installation of the drawer slides: If they are not mounted completely parallel and level, the drawer will bind.
- Lack of lubrication on the slide tracks leads to increased friction.
- Drawers are overloaded or the weight is unevenly distributed.
My advice: First, check all the slides to ensure they are properly seated, preferably using a carpenter’s square. If necessary, loosen the screws, realign everything, and then tighten them again. After that, you can carefully treat the slides with silicone spray—avoid oils or grease, as these attract dust.
Often, this is enough to improve the function without having to completely remove the drawer.
DUVIN
2 Jul 2024 11:45
flo-Theres schrieb:
Often this already helps a lot without having to remove the entire drawer.
I agree with that.
If you take the drawers out, you can thoroughly clean the runners and then lubricate them again. This usually helps before doing a more extensive search.
Domau0
3 Jul 2024 16:22
I often see this problem with PLATSA related to minimal manufacturing tolerances and assembly errors. Here are some extended tips on how to systematically fix drawer sticking issues:
- Use a spirit level to check if the furniture piece is perfectly vertical. Tilts can transfer to the drawers and cause them to get stuck.
- Check the drawer slides for foreign objects or paint residues that can sometimes get in during assembly.
- The drawer boxes themselves must sit completely flat. Even slightly warped or too stiff side panels can press against the drawer slides.
- Sometimes it helps to adjust the slides slightly by loosening the screws and aligning the aluminum slide so that the gap between the drawer side and the slide is exactly the same. Ensure an even gap of about 2-3 cm (1 inch).
- If the drawers are really stuck, pull them all the way out, then lift them slightly to one side and reinsert them. This ‘baking’ can help reposition them.
If the drawer sticks but there is no mechanical obstruction, you should also check whether the back panel of the PLATSA unit is properly seated. It can sometimes be slightly warped and press against the slides.
Maybe you could describe whether the problem occurs with all drawers or only some? And whether you have already tried positioning the furniture differently?
ridipi
4 Jul 2024 08:55
Domau0 schrieb:
Maybe you could describe whether the problem occurs with all the drawers or just some of them?
Good question. Actually, 3 out of 5 drawers stick, unfortunately not all of them. The top two work perfectly, while the bottom three sometimes get stuck, requiring some force to open or close.
Domau0 schrieb:
Have you already checked a specific position of the furniture?
The shelf is standing completely upright in the corner of my apartment, as you suspected, and I have used a spirit level several times; the angle seems fine. The back panel is also glued properly and fits tightly.
I will try your tips about adjusting the drawer slides and especially test the sticking by carefully removing and reinserting the drawers. Thanks for the detailed advice!
V
vin_leo
4 Jul 2024 18:37
ridipi schrieb:
I will try your tips on adjusting the drawer slides and especially carefully removing and reinserting the clamps.
Very good decision!
And if you want a bit of ‘magical fun’ while DIY-ing: sometimes it helps to lightly mark the tracks with a dry pencil—yes, you read that right. The graphite acts as a mild lubricant and is not sticky. This can help reduce minor friction.
Good luck! If the drawers still act up, just get back to us—we’ll figure it out. 🙂
