I am planning to transport a BILLY bookshelf from IKEA because I will be moving soon. I am mainly interested in what to consider when transporting BILLY bookshelves to avoid damage as much as possible. This includes both transporting it by car and carrying it to the new location.
I would also like to know if it is recommended to completely disassemble the shelf or if it can be transported in parts. Are there any specific protective measures you would suggest, such as padding, packaging, or securing it?
If you have experience with the stability of these shelves during transport, that would be very helpful.
Thank you in advance for your tips!
Pobale schrieb:
Are there any specific protective measures you would recommend?Yes, definitely disassemble the shelf first, then transport it flat. Use boxes or blankets for protection to prevent scratches. Secure the shelf boards separately so they don’t shift around.
Pobale schrieb:
whether it is advisable to completely disassemble the shelf or if it can be transported in partsIn general, I recommend fully disassembling the BILLY shelf. The individual components – especially the side panels and back panels – are quite sensitive to pressure and scratches during transport.
To prevent damage during transport, all parts should be well padded. It’s best to use bubble wrap or blankets between the pieces. The back panel is often made from a thinner cardboard-like material – it can easily break or warp if not properly protected.
Also, be sure to keep all fasteners (e.g., screws and dowels) in a labeled bag to avoid losing anything during reassembly. If the shelf is not completely disassembled, make sure it is stable and does not wobble during transport – securing it with straps or tie-downs can help.
Ultimately, the approach depends on the length of the transport and the available means of transport. For short distances and careful handling, parts can be transported assembled, but for safe long-distance transport, I recommend full disassembly.
Paunon schrieb:
Secure the shelves separately so they don’t slipAbsolutely right – and I would add: pack the shelves like little treasures! Bubble wrap or some old towels make perfect protectors for the BILLY shelves during the car trip :-)
Oh, and for safety, watch out for the corners too – they tend to get damaged by hard edges in the car. A bit of padding helps the shelves travel smoothly.
Another tip: try to keep the bookshelf upright when loading. Laying it down can easily cause dents on the thin side panels.
Good luck with packing and transporting! 🙂
Pobale schrieb:
Whether it can be transported in partsIf the shelving unit is not fully disassembled, stress points can occur during transport that may cause deformation. The supplied fasteners are not necessarily designed to withstand prolonged pressure or lateral forces.
Additionally, it is important to ensure the back panel is not damaged, as it significantly contributes to stability. Ideally, back panels should be transported separately and well padded.
A recommendation: when loading into a vehicle, place more durable parts at the bottom and secure delicate components, such as shelves and back panels, on top with padding. Make sure everything is firmly fixed to prevent shifting during transit.
If a station wagon or trailer is used as the transport vehicle, sharp edges and potential friction surfaces should be additionally protected.
