ᐅ What should be considered when installing IKEA Metod wall cabinets?
Created on: 19 Jan 2023 08:17
RONWAYLON
Hello everyone, I am currently planning the installation of IKEA Metod wall cabinets in my kitchen and want to make sure I don’t overlook any important details. My specific question is: What should be considered when installing IKEA Metod wall cabinets, especially regarding the wall structure, proper anchoring, and alignment? Additionally, I am interested in which tools should ideally be available and if there are any special safety tips or precautions to prevent damage to the cabinets. I look forward to a detailed discussion to help ensure my project goes as smoothly as possible.
RONWAYLON
19 Jan 2023 16:22
toril schrieb:
The wall bracket must be installed perfectly level, in the spirit of using a spirit level.
I agree that this is crucial, thanks for pointing it out. Are there any special tips to ensure the rail is installed very straight? I want to avoid having to make complicated adjustments after the cabinets are mounted. Also, I wonder if it’s still easy to reposition the cabinets after the rail has been installed?
anfeteo
20 Jan 2023 07:44
For precise alignment, I recommend the following procedure:
- Use the longest possible spirit level and mark the position of the rail on the wall with a pencil.
- First, drill only the holes, insert the wall plugs, and hang the rail temporarily. This way, you can still make slight adjustments.
- If you have an assistant, have them check the spirit level while you hold the rail.
- The Metod wall cabinets can still be adjusted horizontally and vertically after hanging, before you screw the cabinet sides together.
In summary: With proper preparation and alignment, the installation can be easily adjusted afterward. The wall bracket is the crucial element that must be positioned correctly.
barda6
20 Jan 2023 09:10
Also consider the number of cabinets installed and the load to ensure the wall bracket is properly sized. Screw the cabinets together to increase stability. Many people underestimate this.
warrenka57
20 Jan 2023 11:52
RONWAYLON schrieb:
Are there any special tips for getting the rail perfectly straight?
I once received the advice to temporarily fix the rail with tape first, then check it with a spirit level before drilling. This worked well for me. It helps to avoid unnecessary drill holes. Sometimes marking several points on the wall before drilling also helps.
nonpra
20 Jan 2023 14:04
One last tip: Use screws tightened firmly with a nut, but not too tight, otherwise the material may warp. Cabinets can be later adjusted along the rail, so don’t worry if it’s not perfectly aligned to the millimeter.
