ᐅ What is the optimal screw length for installing Ikea Metod wall cabinets?
Created on: 8 Aug 2021 18:37
narpo54
narpo54
8 Aug 2021 18:37
Hello everyone, I am currently preparing to install some Ikea Metod wall cabinets and am unsure about the appropriate screw length. The cabinets need to be securely mounted to the wall, but the back panel and mounting rail already add some thickness. I am wondering what screw length would be optimal so that the screws are long enough to provide sufficient support in the wall, but not so long that they penetrate through the wall or other materials. Specifically, what screw length is recommended for mounting Ikea Metod wall cabinets on a typical drywall (plasterboard) or concrete wall to ensure secure hold and long-lasting load-bearing capacity? Perhaps someone has experience with different screw lengths and materials and can share their insights. Thanks in advance!
besau
8 Aug 2021 19:02
For concrete walls, I usually use 6x70 mm (¼ x 2¾ inches) screws, which are more than sufficient. For drywall, make sure to use appropriate anchors and do not use screws that are too short; 6x50 mm (¼ x 2 inches) is standard for drywall. It is important that the screw penetrates at least 40 mm (1½ inches) into the anchor.
kulau
8 Aug 2021 20:15
Basically, the optimal screw length for Ikea Metod wall cabinets depends on several factors: - Wall material (concrete, drywall, wood studs) - Thickness of the mounting rail and the cabinet back panel - Type of anchor - Load (weight of cabinets plus contents)
For concrete walls, I recommend screws at least 60 to 70 mm (2.4 to 2.8 inches) long to ensure they are anchored deep enough into the masonry. It is important that the screw is long enough to fully engage the anchor and leave at least 40 mm (1.6 inches) embedded in the wall material. The back panel of the Metod cabinet including the mounting rail is about 15 to 20 mm (0.6 to 0.8 inches) thick. This means you should choose a screw length that covers this material thickness plus at least 40 mm (1.6 inches) in the wall.
For drywall, you should use high-quality drywall anchors and screws about 50 mm (2 inches) long. The screw must be long enough to pass through the back panel, the mounting rail, and the anchor, while still providing good holding strength.
Would you like to provide more details about the wall construction? This helps determine, for example, whether cavity anchors or possibly expansion anchors are needed.
tutan
8 Aug 2021 21:03
Metod wall cabinets have been hanging on my concrete walls for years using 6x70 mm (2.75 inch) screws. This length is ideal because it goes through the back panel and mounting rail and then anchors firmly in the concrete. However, for drywall, you really shouldn’t go too short; the standard 6x50 mm (2 inch) screws with suitable cavity anchors work very well. After all, you don’t want the cabinets to suddenly come loose and fall down 😅. So, having a bit of extra length is always a good idea.
EDWARD0
9 Aug 2021 06:22
I recommend using 6x50 mm screws with suitable cavity anchors for drywall. For concrete walls, use 6x70 mm screws with appropriate anchors. It is important that the anchor is firmly secured; this will ensure the cabinet holds safely.
tolokau
9 Aug 2021 08:44
To bring some structure to this: 1. Measure the thickness of the back panel and the hanging rail, which is usually around 15-20 mm (0.6-0.8 inches). 2. Plan for a minimum of 40 mm (1.6 inches) screw penetration into the wall material. 3. Screw length = back panel + hanging rail + wall penetration. Example: If the back panel plus hanging rail measures 18 mm (0.7 inches), and you want a 40 mm (1.6 inches) anchoring depth in the wall, you need a screw length of at least 58 mm (2.3 inches). 4. In practice, round to a common standard length, such as 60 or 70 mm (2.4 or 2.8 inches). 5. For drywall (plasterboard), use suitable wall plugs and usually keep the screw length closer to 50 mm (2 inches). 6. For solid materials like concrete, 70 mm (2.8 inches) screws are ideal and more than sufficient. 7. Screw thickness: Ikea usually specifies 6 mm (0.24 inches), so stick to that. This should help you plan for securely and permanently mounting the towers.
