ᐅ What safety precautions should be taken when assembling Ikea Hemnes furniture?
Created on: 22 Apr 2021 18:27
NidikinHello everyone, I am planning to assemble an Ikea Hemnes dresser soon and want to make sure it is done safely and securely because these pieces are often tall and heavy, with a risk of tipping over or being unstable.
What specific safety precautions should be taken when assembling the Ikea Hemnes dresser? I am especially interested in measures such as wall mounting, proper fastening of the individual parts, suitable tools or techniques to ensure the furniture is safely put together, and how to avoid accidents during assembly. Are there also tips on how to secure the dresser against tipping if there are children or pets in the household?
I would appreciate detailed advice and experiences to make sure everything is done thoroughly and safely.
NoValentin22 Apr 2021 19:03It is essential to use the supplied wall fasteners and secure the dresser to the wall.
Additionally, you should follow the instructions carefully and tighten all screws securely.
When assembling, it is best to work on a level surface to avoid incorrect installation.
Regarding safety measures when assembling the Ikea Hemnes chest of drawers, I would like to go into detail because stability is critical for safety in living spaces, especially with furniture that has considerable height and weight.
1. Wall fastening: As mentioned before, securing the chest to the wall is essential to significantly reduce the risk of tipping. Ikea usually provides appropriate anchors and brackets for this purpose. Depending on the wall type (e.g., concrete, drywall, wood), you should use suitable anchors. For drywall, special hollow wall anchors are recommended, as standard anchors may fail there.
2. Screws: Double-check all screws after tightening them a few times. During initial assembly, there may still be some play, or the wood might settle. Retightening after one or two days increases stability.
3. Tools: A good, properly sized Phillips screwdriver is a must. Cordless drills can speed up the process but sometimes lead to overtightened screws or damaged threads – so a delicate touch is required here.
4. Assembly area: Assemble on a flat, clean surface. Uneven surfaces can cause parts to sit incorrectly and make the furniture unstable.
5. Edges and cutouts: During assembly, make sure the fronts fit cleanly on the slides and into cutouts to avoid misalignments that can cause stress over time and lead to reduced safety.
6. Usage: If you have children or pets in the household, I also recommend using child safety devices or at least enforcing wall fastening, as tipping can quickly become dangerous otherwise.
I am curious about what type of wall you have. That can help tailor the recommendations more precisely.
Parbo schrieb:
1. Wall mounting: As already mentioned, securing the dresser to the wall is essential to significantly reduce the risk of tipping.That is absolutely correct. Additionally, I would like to point out that the furniture’s secure hold on the wall is only ensured if the supplied wall fixings are installed properly. This means selecting the appropriate type of anchor depending on the wall material (concrete, brick, drywall, etc.).
Parbo schrieb:
2. Screws: Check all screws again after tightening them several times. When assembling for the first time, there may still be some play or the wood may settle. Retightening after one to two days increases stability.This practice is essential for long-term stability. Especially with solid wood furniture like Hemnes, joints can settle slightly under load, making retightening necessary.
Furthermore, I recommend assembling systematically and not fully tightening all screws in one step too early. Instead, first position all screws to avoid tension or misalignment.
Finally, make sure the back panel is correctly and securely fixed, as it greatly increases lateral rigidity and thus also contributes to tipping resistance.
