ᐅ What repairs can you perform yourself on Ikea Platsa furniture?
Created on: 8 Jun 2021 14:23
Ixkate
Ixkate
8 Jun 2021 14:23
I was wondering which repairs on Ikea Platsa furniture can be done by yourself without having to immediately contact customer service or the assembly service. This especially concerns typical issues like loose hinges, doors coming off their fittings, or possibly damaged wooden parts or fronts. I’m also interested in whether there are common weak points you should know about in advance to prevent damage or to easily fix it yourself. Does anyone have experience with what tools are needed and whether replacement parts are easy to obtain? Specific examples from practical experience would be very helpful.
Trenton
8 Jun 2021 15:11
Loose hinges can be easily tightened with a screwdriver. For doors that have come off their hinges, carefully rehanging the hinges often helps. Replacement parts such as screws or hinges are usually easy to obtain from Ikea, often even individually. However, for more significant damage, you should be cautious and check carefully for any cracks in the wood – these parts are usually better replaced entirely.
Laukau5
9 Jun 2021 09:37
Ixkate schrieb:
I am also interested to know if there are typical weak points to be aware of in advance, in order to prevent damage or fix it easily yourself.
That’s a very good question, because especially with the Platsa furniture, there are indeed some areas that are more vulnerable. Typically, these are the connection points between the individual modules, where the metal connectors interact with the wooden panels. Sometimes the screws can loosen over time here, especially if the furniture is frequently moved or rearranged.
A common issue is also the loosening of the hinges on the doors, as they are heavily stressed with daily use. It is recommended to regularly tighten the hinges with the appropriate screwdriver (usually a PH2).
For repairs to damaged wooden parts or fronts, there are a few tips: small scratches can be touched up with a furniture marker in a matching color. For broken edges or damaged corners, caution is advised – depending on the damage, you can use wood glue and clamps if the part is not load-bearing.
In terms of tools, it’s useful to have the following ready:
- Phillips screwdriver PH2
- Hammer and, if needed, a small rubber mallet
- Wood glue
- Furniture markers for touch-ups
- Clamps or screw clamps for gluing
Regarding spare parts: Ikea offers the possibility to purchase many individual parts directly, especially for the Platsa series. It is important to know the exact article number or at least the name of the component. Sometimes the assembly instructions help, as all parts are listed there.
I’d be happy to go into more detail if you are interested in specific repairs or can describe the damages precisely.
kemads46
10 Jun 2021 18:04
Trenton schrieb:
Spare parts like screws or hinges are generally easy to get from Ikea, often even individually.
That’s true, but I recommend checking exactly which parts are needed, especially for Platsa, to avoid ordering unnecessary items. Here is a brief guide on how to handle common repairs yourself:
- Tightening and adjusting hinges: Hinges can usually be easily adjusted with a Phillips screwdriver. If the door no longer closes properly, you can slightly loosen the screws and adjust the position.
- Replacing furniture feet: Platsa uses standardized feet that can be unscrewed and replaced if they are damaged or uneven.
- Repairing damaged screw holes: If the wood is worn out, you can fill the hole with some wood filler, let it dry, and then screw in again.
- Replacing door handles and fronts: Simply swap them with original spare parts or compatible ones that have been carefully measured beforehand.
- Refitting fronts: Front panels often come loose – they are usually fixed with small black plastic fasteners which can be replaced.
All of this can be done with basic tools like a screwdriver, wood glue, and wood filler. For major structural damage, replacing the affected panel or module is usually recommended. I would advise trying gently first if you are unsure, to avoid causing further damage.
