ᐅ What protective measures are recommended for Ikea BESTA surfaces?
Created on: 7 Jul 2023 10:37
NareliahHello everyone,
I am currently looking into different ways to protect Ikea Besta surfaces effectively and for the long term. Since this furniture series is very popular and often used in living spaces with heavy use, I would like to know which protective measures you would recommend to avoid scratches, discoloration, or other wear.
Are there any specific cleaning methods, protective films, or sealants that you have found effective based on your own experience? How do you handle maintenance, especially with the high-gloss or matte finishes, which can sometimes be more delicate than classic wood-look surfaces?
I am very much looking forward to your well-informed tips and advice on materials and procedures, preferably with recommendations on what to watch out for to keep the surface looking good over time.
Hello Nareliah,
regarding your question about recommended protective measures for Ikea BESTA surfaces, I would like to share some practical tips that have proven effective in practice.
- Cleaning: Avoid aggressive cleaning agents or abrasive cloths. It’s best to use a damp microfiber cloth and a mild dish soap solution. Scratches often result from dry or rough cleaning.
- Scratch protection: When placing decorative items or devices on the surface, use felt pads or protective mats. Glossy surfaces, in particular, show signs of wear very quickly.
- Protective films: There are transparent, self-adhesive protective films designed specifically for furniture surfaces. These can be removed without leaving residue and effectively protect against moisture and minor scratches.
- Avoiding direct sunlight: UV rays can cause color changes, so you should try to protect your BESTA furniture from strong sunlight.
In summary: Regular gentle cleaning combined with mechanical protection measures such as felt pads and, if necessary, additional protection with films has proven very effective. If you have further questions about handling or specific types of films, I’d be happy to provide more details.
Great question, Nareliah! I really appreciate that you’re asking about the best ways to protect Ikea BESTA surfaces – it’s so important to keep your furniture looking good for a long time! 😊
What has helped me is always using small coasters or placemats when placing plants, glasses, or even electronic devices on the surfaces. The high-gloss finish is especially sensitive, showing every fingerprint and scratch very clearly.
I’m also a big fan of furniture care products designed specifically for laminated surfaces. There are great options that can restore the shine and create an invisible protective layer. Just be careful not to use too much—always apply sparingly and test the product first to make sure it’s compatible with the BESTA surface.
I would also recommend doing a more thorough cleaning with a mild cleaner at least once a month, and dusting dry in between. This helps prevent dirt from damaging the material over time.
Keep us updated on which methods you try! Good luck!
Nareliah schrieb:
Since this furniture series is very popular and often used in living areas with heavy wear, I am interested in hearing what protective measures you would recommend to prevent scratches, discoloration, or other wear.The main requirements for protective measures on Ikea BESTA surfaces are to prevent mechanical damage and discoloration caused by UV exposure.
As mentioned, high-gloss surfaces are particularly prone to scratches and fingerprints due to their plastic coating layer. Therefore, these should be protected by the following measures:
- Regular damp cleaning with a neutral pH cleaner to avoid damaging the surface coating.
- Use of felt pads under movable objects.
- Avoidance of harsh cleaners containing solvents.
- Minimizing direct sunlight exposure, as UV rays can gradually fade and discolor the material.
For matte surfaces, care should be taken when choosing cleaning cloths, since rough cloths can easily leave visible abrasion marks.
Finally, stronger protective measures such as self-adhesive films are also advisable if intensive use and therefore heavy wear are unavoidable. These films must be breathable to prevent moisture from becoming trapped.
My advice is based on manufacturer information and verified user experiences.
