ᐅ What issues commonly occur with IKEA Hemnes furniture during long-term use?
Created on: 24 Mar 2021 10:37
tuteo60
tuteo60
24 Mar 2021 10:37
Hello everyone, I have quite a bit of experience with IKEA furniture, but my current question is specifically about the Hemnes range, which I have been using intensively for over two years now. I’m interested in knowing what typical issues or signs of wear appear with Hemnes furniture in everyday use, especially when items like cabinets or dressers are heavily used. I’m not just asking about damage from direct stress, but also about material fatigue, hinges, rollers, or small defects that might develop over time. I would also like to hear how others assess the durability of the surface finish, particularly with the white lacquered versions, and whether discoloration or scratches are common. I look forward to your experiences and insights on what to realistically expect with long-term use and which weak points have proven to be reliable—or not.
giabau
24 Mar 2021 12:43
Hello tuteo60, thank you for your detailed question. I have used Hemnes dressers and cabinets for several years and can share some insights. The most common issues I have observed are:
- Hinges: Especially on frequently used doors, the hinges tend to loosen fairly quickly. It helps to occasionally tighten or replace them, as the original ones are functional but not particularly durable.
- Material: Hemnes furniture is usually made of spruce wood, which looks great but is prone to minor dents and scratches under heavy use. The surface is not fully lacquered but often oiled or waxed, making it easier to refinish but also showing wear faster.
- Drawers: The runners or rollers can wear out over time, leading to jerky movements. Regular cleaning and possibly re-lubricating the sliding mechanism significantly improves function.
- Color changes: Especially with white versions, a slight yellowing often appears over time, likely caused by UV exposure and household dust.
In summary, I would recommend regular maintenance for Hemnes furniture and timely replacement of worn parts. Overall, the furniture is attractive and sturdy but not designed for intensive, heavy-duty use over long periods.
putan
25 Mar 2021 09:52
giabau schrieb:
The surface is not fully painted but often oiled or waxed, which makes it easier to re-treat but also shows wear more quickly.
That’s exactly what I noticed too! My white Hemnes bed developed quite a few visible signs of use after about a year—not big scratches, but the corners and edges suddenly look a bit duller and have that "used charm." 😉
I also find that dust tends to settle quickly on the surfaces, which is helped by the somewhat rough texture. So if you like everything to look flawless, you’ll need to clean or refresh the Hemnes furniture more often.
With the drawers, I occasionally felt that after longer use they didn’t run as smoothly. A little WD-40 here and there helps, but in my opinion, that shouldn’t be the normal state. Overall: for the price, the Hemnes furniture is really great, but it does require some care—and that’s to be expected with solid wood furniture!
pinDavid
26 Mar 2021 18:11
tuteo60 schrieb:
which typical problems or signs of wear occur with Hemnes furniture in everyday use, especially when it is heavily used
In short: The most common issues are loose hinges, stiff drawers, and surface wear (especially on white or light-colored finishes).
The material is sturdy, but with daily use, small dents and slight discoloration from sunlight or dust develop quickly. Additionally, care must be taken with the maintenance of oiled or waxed surfaces.
From a mechanical standpoint, regularly adjusting the hinges and lubricating the sliding mechanisms helps maintain good condition.
