ᐅ What are the most common issues encountered when assembling IKEA Brimnes furniture yourself?
Created on: 11 Jun 2024 08:37
Mia-plo
Mia-plo
11 Jun 2024 08:37
I recently purchased the IKEA Brimnes furniture set and am now considering which common issues occur most often during self-assembly. Especially with more complex IKEA sets like Brimnes, there seem to be frequent difficulties that unnecessarily extend the assembly time or later cause instability.
Specifically, I am interested in the challenges you have experienced while assembling Brimnes furniture. Are the problems mainly unclear instructions, missing or poorly fitting parts, difficulties with the screw system, or typical assembly mistakes that should be avoided?
Are there any special tips for avoiding these common sources of error? I would also like to know which tools or methods have proven particularly helpful.
I look forward to hearing about your experiences!
pikin
11 Jun 2024 09:12
In my experience, the most common issues with Brimnes furniture are:
- Imprecise assembly instructions, especially for installing the back panel
- Furniture screws and dowels sometimes not fitting perfectly, leading to loose connections
- Missing or wrongly delivered parts are rare but can cause additional delays
My advice: Sort and check all parts before starting to avoid interruptions later. Also, using your own drill or cordless screwdriver with torque control helps prevent over-tightening the screws.
Leote
11 Jun 2024 11:04
The instructions are often hard to understand. Small parts are frequently mixed up. Be careful with the hinges; they need to be positioned precisely, otherwise the doors will stick.
Dilen
11 Jun 2024 14:27
I would like to discuss the topic in more detail, as self-assembly with Brimnes involves some technical pitfalls.
Leote schrieb:
The instructions are often difficult to understand.
That’s true, especially the presentation of the exact alignment of the back panel and the dowel holes built into it is often insufficient. This frequently leads to misalignment and an unstable structure.
Additionally, I often find that the drill holes in the wood do not precisely match the metal screws, which means you have to be very careful when screwing in to avoid cracking the wood. Using a drill with a small bit for pre-drilling can be helpful here.
When connecting the parts, it is often underestimated that the tension from the back panel is essential for the overall stability. It must be mounted exactly and correctly tensioned in some models, otherwise the entire unit will warp over time.
Have you noticed if these problems occurred for you as well, and how did you solve them? This question is particularly focused on the technical side and possible practical solutions.
flo-Theres
11 Jun 2024 16:53
Regarding the back panel and stability, I would like to mention the following: With Brimnes, it is important to place the back panel flat first and insert the screws according to the instructions, but do not tighten them immediately. Only once all screws are in place should you tighten them. This prevents tension.
From my own experience, I can add that it is advisable to adjust the hinges before installation and check that they fit securely. Even the slightest misalignment can result in permanently crooked doors.
Mia-plo
12 Jun 2024 07:18
pikin schrieb:
My tip: Sort and check all parts before starting to avoid interruptions later.
That’s a great tip. I had planned to do that anyway, but your additional advice about torque control is definitely helpful, especially for furniture screws. I often worry about overtightening and damaging the material.
Dilen schrieb:
A drill with a small bit for pre-drilling can be useful here.
However, I’m unsure if pre-drilling might void the warranty. Does anyone have specific experience or recommendations on how to do it carefully and with proper checks without risking anything?
