ᐅ What problems can occur if the Ikea Hemnes is assembled incorrectly?
Created on: 21 Aug 2021 18:37
nudukenI have a rather technical question for the community: What specific problems occur if the IKEA Hemnes furniture is assembled incorrectly? I mean errors that are not just cosmetic but could also affect stability, functionality, or safety. For example, I’m interested in issues like: Does the furniture warp, are there increased risks of accidents, do the drawers become harder to open, or is there even a danger of the furniture falling apart? I have noticed that with Hemnes, screws are often fastened in the wrong order or parts are installed upside down. How exactly does this affect everyday use? This is an important topic for me because I am assembling the furniture myself and do not always follow the assembly instructions exactly.
JEREMIAH3821 Aug 2021 19:02I completely understand your concerns.
From my own experience, I can say that incorrect assembly especially affects the stability. If certain screws are not properly tightened or components are twisted, the furniture wobbles significantly and it feels unsafe—particularly when it is used regularly.
That is exactly what I experienced! My Hemnes wardrobe almost tipped over because a corner bracket remained loose. I was quite afraid that someone could get hurt, especially with children in the house.
It is also important to note that drawers don’t slide properly if the runner rails are not installed correctly. This might not cause immediate damage, but it is very annoying and over time the material can be damaged as a result.
My advice to you: take your time and check all connection points multiple times during assembly. It often helps to insert all screws loosely at first, then tighten them properly at the end. This way, you avoid unnecessary tension and misalignment.
nuduken schrieb:
If the furniture warps, the risk of accidents increases
Allow me to explain the topic in more detail from a technical perspective.
The IKEA Hemnes series is mostly made of solid wood with appropriate fasteners such as screws, dowels, and metal fittings. If the assembly instructions are not followed precisely, various problems can occur – which can be grouped into several categories:
- Loss of stability: Incorrectly placed screws can cause the load-bearing joints to be unable to support the required weight. This often results in deformations or even cracks in the wood.
- Functional issues: Drawer slides are especially sensitive when the wrong screw lengths or screw positions are used. Drawers may then stick, be difficult to open, or become completely jammed.
- Safety concerns: Improper wall mounting, such as incorrect installation of the special anti-tip device, increases the risk of the furniture tipping over and causing injury.
- Aesthetic problems: Warped parts, protruding screws, or misalignments significantly affect the overall appearance and also make adjustments more difficult.
For long-term use, it is important to follow the correct sequence of steps and adhere to the recommended torque values. If possible, I recommend double-checking steps before fully tightening screws— for example, by taking photos or getting a second opinion.
I am curious whether your Hemnes is more of a cabinet or a bed; some variants have different assembly sensitivities, especially regarding weight and load. How far along are you with your assembly?
I wonder, considering the whole discussion: How likely is it actually that the average user assembles IKEA Hemnes furniture so incorrectly that it causes significant issues?
To me, that sounds more like a lack of final checking rather than a difficulty in the assembly process itself.
Basically, IKEA provides quite clear instructions. I doubt that incorrectly installed parts or missed screws would systematically cause problems as long as you follow the instructions.
So, I would consider this more of a user error rather than a flaw in the design or the assembly manual.
In short: The question is whether we are dealing with actual weaknesses in the product here or just the typical beginner mistakes when assembling furniture. Clearly, the former would be concerning, but the latter is probably the norm when someone is inexperienced.
jeremiah38 schrieb:
My Hemnes wardrobe almost tipped over because an angle bracket remained loose.
