ᐅ What are the most common issues encountered with IKEA BRIMNES drawers?
Created on: 7 Oct 2022 18:37
tufra
tufra
7 Oct 2022 18:37
A few months ago, I purchased several IKEA Brimnes dressers with drawers. I have noticed that these drawers tend to have recurring issues that I did not expect. I am particularly interested in which technical or mechanical weaknesses tend to occur most frequently with the Brimnes drawers and how you have resolved these problems.
More specifically: Do you often experience issues with the smoothness of the drawer slides, drawers getting stuck, problems with load capacity, or is the assembly not always straightforward? I am also curious if there are any material defects that cause long-term functional limitations.
Who has extensive experience with the durability and workmanship of the Brimnes drawers and can share which typical problems are actually most common and whether these can be explained by design details?
Thank you in advance for your insights!
BARSAN
7 Oct 2022 18:56
Most of the time, it is the drawer slides that wear out or stick quickly. Additionally, the drawer often jams if it is not precisely aligned. Too much weight? Then the load capacity can be exceeded.
teyosef
7 Oct 2022 19:43
I would like to provide a more detailed explanation of the typical issues with BRIMNES drawers:
1. Smoothness and track problems: The drawers use simple metal rollers on plastic rails. Over time, these often become stiff because the plastic wears down or the rollers accumulate dirt. Regular cleaning and, if necessary, lubrication with silicone spray can help.
2. Load capacity: BRIMNES drawers are designed for moderate loads. If the permissible weight limit is exceeded, the drawer base panel may deform or the frame may begin to twist. This is noticeable through sagging or tilting drawers.
3. Assembly errors: Incorrect installation of the rails is very common and can cause jamming. It is important that all screws are fully tightened but not over-tightened to avoid gaps and tension.
4. Material quality: The MDF material is durable, but moisture or excessive load can cause it to swell.
In summary, I recommend keeping loads within the specified limits, carefully checking mounting points, and regularly maintaining the guide elements.
Davidleo
7 Oct 2022 20:12
I really like the BRIMNES drawers, but yes, the runners sometimes gave me trouble too! 😅
The tip about cleaning and lubricating is priceless! It makes everything run smoothly. I've kept trying to avoid overloading them, and it works great! So keep at it, you can do it! 👍
Ethan
8 Oct 2022 10:21
Hello tufra and all interested readers,
to explain a common issue with IKEA BRIMNES drawers more precisely: sticking when closing or opening is often caused by the drawer not being perfectly square within the cabinet or the sliding rails shifting due to slight deformation. This results in friction on the guide rails or the drawer body.
BARSAN schrieb:
Most often, it’s the drawer slides that quickly wear out or catch.
The wear of the slides mainly occurs with heavier and more frequent use, as the plastic rollers and plastic rails wear down at the contact points.
It is also evident that frequently overloading the drawers overloads the entire mechanism, which leads to problems even after a relatively short period of use.
I recommend always adhering to the manufacturer’s specifications regarding maximum load, as otherwise damage is inevitable. Additionally, it is advisable to regularly clean the slides from dust and dirt, possibly using a soft brush and a light lubricant (but not oil, as it attracts dust).
Proper installation is also crucial: loose screws or misaligned rails often cause the described problems. When tightening screws, care should be taken not to damage the material.
If anyone wants, I can gladly prepare a short installation checklist.
