ᐅ What common issues occur with IKEA Metod baseboards/kickboards?
Created on: 1 Apr 2017 09:13
gakumin
gakumin
1 Apr 2017 09:13
Hello everyone, I would like to start a discussion on the topic “What common problems occur with IKEA METOD baseboards?” as I have recently encountered increased difficulties during installation and use. Specifically, I want to find out if other users have had similar experiences, particularly regarding the fit of the baseboards, attachment methods, as well as issues with the material or durability. During my kitchen planning, I noticed that some baseboards do not fit together precisely or come loose after a short time, which is quite frustrating. I am also interested in how different substrates affect the installation and whether there are any alternative mounting options. Are there any issues with standardized dimensions, material warping due to moisture, or general quality defects? Any experiences, including technical details, would be very helpful, especially for people like me who want to minimize rework. Looking forward to the exchange!
PIDAN
1 Apr 2017 09:47
I am happy to provide a structured overview of common issues with IKEA METOD baseboards:
- Fit accuracy: Although the baseboards are designed to be modular, reports indicate difficulties in achieving a precise connection between two or more sections. Causes include manufacturing tolerances and unfavorable angles in the room.
- Fixing method: Many users complain about the simple click mechanisms and adhesive strips, which do not hold permanently on certain wall types. Durability is especially limited on uneven or porous surfaces.
- Material issues: Plastic baseboards tend to warp depending on the room climate, particularly in high humidity. This often leads to stress or gaps.
- Compatibility: Due to standardized dimensions, more individual adjustments are needed than expected, requiring on-site cutting work.
As a tip, it is recommended to carefully check the wall condition before installation and, if necessary, use additional fasteners (e.g., screws). The use of expanding foam can also help with uneven areas.
goron
1 Apr 2017 10:03
I can confirm: The trim pieces often do not fit precisely, especially at corners. You notice this quickly. Adhesive does not hold well on rough walls. Screws usually work better in these cases.
blaix
1 Apr 2017 10:38
Interesting points have already been raised here. However, I wonder if the issues really lie with the METOD baseboard itself or more with the typical installation environment of IKEA kitchens.
PIDAN schrieb:
The baseboards are designed to be modular, yet reports indicate difficulties in achieving a precise connection between two or more sections.
Modularity makes sense in principle, but if manufacturing tolerances cause such connection problems, this is clearly a quality issue.
Additionally, the structural load and the long-term effects of moisture should be considered. Is there perhaps too much focus on appearance and easy installation instead of lasting functionality? I think IKEA could be more transparent about this.
FLONE41
1 Apr 2017 11:05
I appreciate that these questions are asked so specifically. Personally, I struggled for a long time with the baseboards because they actually came loose after a few months. This was disappointing since I don’t use the kitchen often and the surface was relatively smooth.
goron schrieb:
Adhesive doesn’t hold on rough walls. Screws usually help here.
I can confirm that. It helped me to additionally secure the baseboards with small nails, even though that of course isn’t the original installation method.
However, I also know that many are hesitant to do this because ideally, everything should be built to allow for easy removal without damage. Unfortunately, for me, this was the only solution to make everything fit properly.
Danabla
2 Apr 2017 08:22
Summary based on technical insights and user feedback: The main issues with IKEA METOD baseboards are:
- Material: The PVC or plastic material used is sensitive to temperature fluctuations, which can lead to deformation.
- Installation: Using only clips or adhesive strips on uneven or porous surfaces often results in poor holding strength. Screw mounting is recommended.
- Dimensional accuracy: Manufacturing precision plays a crucial role here as well. There are frequent reports of inaccurate cut edges causing gaps.
Recommendations:
- Carefully inspect the wall structure before installation.
- Use additional fasteners where possible.
- Measure meticulously and, if necessary, use professional tools for cutting.
- In cases of high humidity, consider alternative materials or use sealants.
These measures prevent many of the described problems.
