ᐅ What common problems are often encountered with Ikea Brimnes drawers?
Created on: 6 Nov 2021 18:17
rachen
rachen
6 Nov 2021 18:17
Hello everyone, I have a specific question about the Ikea Brimnes drawers: What problems are most commonly experienced with these drawers? I have been using the Brimnes chest of drawers for a few months now and have noticed that the drawers sometimes operate with difficulty or get stuck when fully extended. I am particularly interested in whether this is a general issue with the sliding mechanism or if it might be due to incorrect installation. The stability of the drawers themselves also seems to be sometimes less than ideal, especially when they are heavily loaded. Has anyone had similar experiences and can describe which defects or issues occur most often? Thanks in advance for your insights!
NUPIN
6 Nov 2021 19:03
Hey rachen, I know this issue all too well! The Brimnes drawers are generally very practical, but there are a few common problems that almost everyone has experienced at some point.
- Usually, the rail system is the main weak point: the drawers often stick, especially when they are overloaded or not perfectly aligned.
- Another frequent issue is that the rails can loosen or bend slightly over time, which affects how smoothly the drawers operate.
- Many also report that the strength of the drawer bottoms is limited. If you put too much weight in, they can easily sag.
My advice is to stay persistent, adjust if needed, and watch the weight you put inside! These issues can all be improved. You’ve got this!
NOAHSAU
7 Nov 2021 06:42
NUPIN schrieb:
Usually, the rail system is the number one weak point: drawers often stick, especially when they are too full or not precisely aligned.
That may well be true, but I think the issue is more fundamental: you simply can’t expect long-term quality from an inexpensive piece of furniture like the Brimnes drawer. The materials and mechanisms are designed to reduce costs—anyone expecting more is bound to be disappointed.
Besides, this is often overstated: whether a drawer sticks or jams usually depends on how carefully it was assembled. If it was put together incorrectly, the manufacturer shouldn’t be blamed.
I would even go so far as to say that Brimnes drawers are more of a disposable product for short-term use rather than furniture meant for long-term use. And that’s not necessarily a bad thing, as long as you adjust your expectations accordingly.
TEOZAR
7 Nov 2021 11:28
Hello everyone, I would like to add some additional information about the function and common issues with Ikea Brimnes drawers. As rachen correctly pointed out, the main problems often involve the runners and stability.
The runners are easy to install but require precise alignment; otherwise, they can quickly become sticky or jammed. Load also plays an important role: excessive weight can deform or shift the runners.
It should also be noted that the drawer bottoms can only support certain loads because they are made of very thin MDF. Heavy contents may cause bending or even tearing at the joints.
My recommendation: For heavier items, it’s better to look for other storage solutions. Regularly adjusting the drawers and avoiding overloading them will prevent many problems. This roughly matches what has already been said here; I just wanted to summarize it systematically.
