ᐅ What issues can arise with Ikea Brimnes furniture after moving?
Created on: 19 Oct 2019 09:37
karlis
karlis
19 Oct 2019 09:37
I have read several times over the past few weeks that the IKEA Brimnes wardrobe or furniture piece causes some problems after a move. I would be interested to know what specific difficulties occur, especially regarding stability, assembly, and possible material fatigue or damage from frequent disassembly and reassembly. Are there any experiences indicating whether the number of moves affects the durability? And how does the fit of the individual parts hold up after multiple times of taking it apart?
Perhaps you could also share tips on how to avoid damage or extend the furniture’s lifespan despite moving.
Thanks for your feedback!
diManuela
19 Oct 2019 10:46
Hello karlis,
your question is very well formulated, and I can share some experience. With the Brimnes, please note the following:
- Stability often decreases after several moves because the connecting holes in the wood tend to wear out over time.
- Especially the back panel, which is usually only fixed with nails, can become damaged quite quickly, reducing the overall stability.
- When repeatedly assembling and disassembling, screws and wooden dowels may no longer fit tightly, leading to wobbling.
To counter this, it is advisable to use new screws or additional brackets during reassembly. Carefully positioning the back panel and possibly adding reinforcements can also help. In cases of material fatigue, replacing individual parts may sometimes be necessary, which is generally possible with IKEA, but of course not always practical.
If the cabinet needs to be taken apart and reassembled very often, it is also important to follow the correct order of assembly and avoid tightening screws too much to prevent unnecessary damage to the wood.
tra_nina
19 Oct 2019 12:03
diManuela schrieb:
Stability often decreases after multiple moves because the joint holes in the wood become worn over time.
This is exactly the core issue with Brimnes. The materials and the type of connections are not designed for frequent disassembly. The particleboard panels have limited tensile strength, which leads to edge fraying and loosening when taken apart frequently.
Factors that play a role:
- How carefully the furniture is dismantled
- Whether the screws are properly loosened using appropriate tools
- The storage of the individual parts during the move
According to the manufacturer’s information, this wardrobe is intended for stationary use, not as a move-friendly piece of furniture.
My recommendation for those moving: use protective measures during transport, such as corner protectors and sturdy packaging, and keep spare screws and a repair kit on hand. Even Brimnes furniture taken apart and reassembled twice may lose stability, so this should be taken into account.
TEBILO
20 Oct 2019 07:29
Hello karlis, I like to go into some detail because this topic is quite complex.
Regarding the material: IKEA Brimnes is primarily made of particleboard with a melamine coating and a thin back panel made of hardboard. These materials are sensitive to stress from assembly or disassembly cycles.
The following problem areas are typical:
- Connection holes: IKEA typically uses wooden dowels and metal connector fittings. After repeated disassembly, the dowel holes may widen, causing a loose fit.
- Screws and nails in the back panel reduce its holding capacity. Frequent removal can cause the back panel to warp slightly, which can affect the stability of the carcass.
- Strike strips on doors and drawers may warp if handled improperly or during transport due to bending.
When moving, it is advisable to fully disassemble the wardrobe if possible and store it well packed (soft padding around edges and sensitive parts). Screws and fittings should be kept separately in bags and protected from loss.
I also recommend filling the existing dowel holes with wood filler when reassembling, or ordering complete replacement panels from IKEA through their spare parts service if there is more significant damage. Assembly tools should be set to the correct torque to avoid over-tightening.
Have you noticed any specific damage yet, or are you currently planning a move with Brimnes? That would help tailor the advice more precisely.
karlis
20 Oct 2019 11:11
TEBILO schrieb:
Have you already noticed any specific damages, or are you currently planning a move with Brimnes?
Thank you for the detailed response! Actually, I have a move planned in about two weeks. I own two Brimnes wardrobes, each of which has been assembled and disassembled roughly three times. During this process, I noticed a slight wobble in one wardrobe and some minor scratches on the edges, probably due to rough handling during transport.
Your suggestions about using wood filler for the dowel holes and replacing screws sound reasonable. I’m also wondering if it’s generally advisable to have spare parts ready before assembly, or if that only makes sense when some furniture pieces are already damaged?
Another question I have is about the stability when combining modules. For example, if you place and connect two Brimnes wardrobes side by side—does this create better stability after several moves, or is it unrealistic to expect that after repeated assembly and disassembly?
Looking forward to your opinions!
BOSULE
21 Oct 2019 08:04
karlis schrieb:
How stable is the combination of the modules? For example, if you place and connect two Brimnes cabinets side by side – does this result in better stability after several moves, or can you forget about it with repeated disassembly and reassembly?
Hello karlis,
combining Brimnes cabinets can indeed improve stability, but only if the connection is done properly. IKEA offers connecting fittings that secure two modules together. These reduce the risk of tipping and wobbling.
However, a downside is that these connection points themselves become vulnerable with frequent disassembly and reassembly. The connection holes can widen, which reduces holding strength. So, if you transport your cabinets often, it is advisable to reinforce the connections with metal brackets or perform minor repairs occasionally.
Overall, Brimnes systems are designed more for permanent stationary use and less for frequent disassembly and reassembly. You should monitor the wear and consider acquiring replacement panels or connectors if you plan many moves.
Additionally, gluing or permanently fixing the cabinets together does increase stability but makes later reassembly and transport more difficult.
