ᐅ What issues can arise when disassembling Ikea Hemnes furniture?
Created on: 7 Jun 2024 09:16
PijudeHello everyone,
I am currently facing the challenge of disassembling an Ikea Hemnes piece of furniture (specifically a chest of drawers with multiple drawers) to prepare it for moving. I have noticed that disassembling it is sometimes not as intuitive as assembling it. My questions are: What common problems occur when taking apart an Ikea Hemnes? Are there typical areas where extra care is needed to avoid damage? And are there recommended methods or tools that make disassembly easier? I want to proceed as professionally as possible to be able to reassemble the furniture later without any issues.
Thank you in advance for your experiences and tips!
Hello Pijude,
a very well-formulated question with a clear description of the problem!
When disassembling the Hemnes series, it often happens that the screws and dowels do not come out as easily as they did during assembly, either because they have been slightly tightened or mainly because they are anchored in the wood. Here are my key tips:
- It is best to use a cordless drill with adjustable torque to avoid damaging the screws.
- Most problems occur at the wooden connectors (the so-called cam lock fittings), which should be released carefully to prevent them from tearing out.
- Make sure to completely remove the drawers before taking the dresser apart.
- If wood glue was used, some areas may be more difficult since the parts might be slightly glued together.
It is also advisable to reverse the order of disassembly exactly from the assembly sequence, so you don’t loosen any connectors that are still under tension.
If you want to know more precisely where the critical points are, I can gladly provide you with a more detailed response.
Hello Pijude,
GiRoyce’s advice is already very helpful. Additionally, I can add the following:
- When working with the Hemnes furniture, you should use leverage tools carefully. Although the wooden panels are sturdy, splintering can occur if too much force is applied during disassembly.
- The drawer slides are often secured with small clips or screws and can easily break if removed incorrectly.
- I recommend keeping all screws, dowels, and small parts in labeled bags – this makes reassembly much easier.
Tools: A screwdriver with the correct bit for the cross-head screws, an Allen key for cam lock fittings, and a rubber mallet for gentle tapping are almost always useful.
GiRoyce schrieb:
Most problems occur with the wooden connectors (the so-called cam lock connectors), which should be loosened carefully, otherwise they can tear out.This is correct and important to emphasize: cam lock connectors are the core component of many flat-pack furniture pieces, including the Hemnes series. Depending on how tightly the screws are fastened, these connections can be damaged if loosened improperly, compromising stability during reassembly.
Additionally, care should be taken to avoid applying lateral force when loosening the screws, as this can cause misalignment of the pre-drilled holes. This mainly affects dowels and biscuits, which may no longer fit properly otherwise.
Another common weak point is the soft pine wood used in Hemnes. With repeated assembly and disassembly, it can crack, especially along the edges. Therefore, it is best to proceed step by step and without rushing.
Summary:
- Loosen cam locks carefully
- Unscrew screws straight out
- Avoid levering force
- Be cautious with soft wood
Following this approach greatly reduces damage.
Hello Pijude,
I have put together a simple step-by-step guide for disassembling Ikea Hemnes dressers that might be helpful for you:
1. Preparation:
- Get a furniture screwdriver, Allen key, rubber mallet, and possibly plastic wedges ready.
- Empty and remove the drawers.
2. Removing the back panel:
- It is often fixed with small nails; carefully pry them out with a flat tool.
3. Separating the top and bottom parts of the dresser:
- Loosen the screws on the sides and at the back corners.
- Turn the cam locks with the appropriate tool until they release.
4. Carefully detach the side panels from the front panel:
- Watch out for dowels, as these can become loose from frequent disassembly.
5. Collect and label screws and fittings.
Common mistakes:
- Unscrewing screws too quickly and damaging the threads.
- Using excessive leverage when removing the back panel.
- Failing to document the order of disassembly.
Tips:
- Take photos during disassembly to make reassembly easier.
I hope this guide helps you!
1. Preparation:
Common mistakes:
Tips:
