ᐅ What practical tips are there for replacing Ikea PLATSA doors?
Created on: 19 Apr 2015 08:37
Medosau
Medosau
19 Apr 2015 08:37
I am planning to replace the doors on my Ikea PLATSA wardrobe because I want to change the design while keeping the furniture’s original functionality as much as possible. I have some questions regarding this: What practical tips are there for replacing Ikea PLATSA doors to make the process as efficient and clean as possible?
I am particularly interested in whether there are any special considerations when removing the old doors, the best way to attach the new doors, and if there is anything specific to watch out for with the hinges. Also, whether any special tools are needed for the replacement or if common issues can be avoided.
I would be very grateful for any helpful advice!
Fareo65
19 Apr 2015 09:04
Regarding the replacement of doors for Ikea PLATSA, I recommend a structured approach:
- First, carefully remove the old doors by loosening the hinges on the furniture – Ikea uses simple clip hinges that can be unlocked by pressing a lever.
- It is important not to completely remove the screws to avoid losing the hinges.
- For the new doors, ensure that the hinge mounts are positioned correctly; if necessary, pre-drill holes using a quick-release drill bit with a 3 mm (1/8 inch) diameter.
- Tools needed: a Phillips screwdriver and a cordless drill are sufficient.
- Finally, I recommend carefully checking all door alignments with a spirit level to ensure consistent closing gaps.
Work cleanly and store screws carefully to ensure everything fits later.
flota
19 Apr 2015 10:23
I would like to add that when renovating old doors, one of the practical issues is that the magnetic catches or dampers on PLATSA doors can sometimes stick a little.
A small tip: Lift the doors slightly and gently pull them forward with some finesse. This helps prevent damage to the edges.
Also, if you want to replace the doors, make sure to check the thickness and material of the new doors beforehand. They need to be compatible with the existing hinges because otherwise the gaps won't align properly and the doors won’t close correctly.
In my experience, it’s helpful to roughly adjust the alignment before final fastening and to test how the doors hang overnight.
alvalo
19 Apr 2015 12:11
Hello Medosau,
I can understand your situation well, as some steps in replacing doors are not immediately intuitive. Here is a more detailed overview:
- First, you should ensure that the new doors have exactly the same thickness and weight; otherwise, the hinges may need to be replaced or adjusted.
- With PLATSA, the positioning of the hinges is also important: The Ikea system usually works with standardized drilling patterns. Check these carefully, especially if you want to use doors from third-party suppliers.
- If you use lighter doors, they might not close on their own. In that case, additional magnetic catches can help.
- I recommend wearing gloves while working because the edges of the doors can sometimes be quite sharp.
- Required tools: Besides a screwdriver and cordless drill, a spirit level and a square are very useful to align the doors properly.
I hope these tips are helpful to you.
V
vinli
20 Apr 2015 07:54
Fareo65 schrieb:
For the new doors, you should make sure that the hinge fixings are positioned correctly; if necessary, pre-drilling is required – a quick-release drill bit with a 3 mm (1/8 inch) diameter works well for this.
This statement is absolutely correct. I would like to add that marking the drill holes with a sharp pencil point and a stop helps achieve precise placement.
Another tip: When installing the doors, don’t just lift them into place, but temporarily secure them with a second person or a simple support. This prevents misalignment and damage.
It also helps avoid bending the hinges due to excessive pressure.
Morgan
20 Apr 2015 09:12
flota schrieb:
Also: If you want to replace the doors, be sure to check the thickness and material of the new doors beforehand.
I had a similar experience when I replaced my doors – I initially ordered different doors and then realized the material was too heavy, which put extra strain on the hinges. That’s why I recommend checking not only the dimensions but also the weight of the doors in advance to avoid lengthy adjustments later.
And sometimes patience is key: at first, I discarded several doors until I found an acceptable fit. So make sure to allow yourself enough time to properly install all the doors instead of rushing.
