ᐅ What are the options for repainting Ikea Metod cabinets?
Created on: 8 Jul 2015 20:23
margotbl54
margotbl54
8 Jul 2015 20:23
Hello everyone, I am planning to repaint my Ikea Metod kitchen cabinets and am looking for the best options and methods. The cabinets are currently painted white but show some signs of wear, and I want to change their color without having to replace them completely. It is important to me that the new paint adheres well, especially against moisture and typical kitchen wear, and that the surface appears as smooth and professional as possible.
I have read that there are different types of paint, surface preparations, and alternative techniques like vinyl wraps or special spray paints, but I am unsure which approaches are truly recommended, especially for the Metod series, which usually has melamine or laminate surfaces.
Which types of paint do you recommend, and what about surface preparation? Is sanding absolutely necessary, or is primer enough? What tools are required for a proper paint job? Are there any proven tips to achieve a good and long-lasting result?
I look forward to your experiences and suggestions.
erikpu
9 Jul 2015 08:12
margotbl54 schrieb:
The cabinets are currently painted white but show slight signs of wear, and I want to change their color without having to replace them completely.
That’s a good approach.
Ikea Metod cabinets usually have surfaces made of melamine or laminate foil, which are not easy to paint directly. Proper preparation is crucial: clean the surface thoroughly, lightly sand it (with fine sandpaper, grit around 220) to roughen the surface so the paint adheres better. Then apply a primer, ideally a bonding primer suitable for plastics or smooth surfaces.
For the paint, I recommend an acrylic- or alkyd-based paint designed specifically for furniture. Make sure it is suitable for kitchen areas and moisture-resistant. Spray paint can help achieve an even finish; alternatively, a fine-textured roller works well.
For the final layer, a matte or satin clear coat is advisable to protect the surface and increase durability.
One more tip: allow plenty of drying time between coats to ensure a good result. In summary:
- Clean
- Sand (220 grit)
- Prime (bonding primer for plastic)
- Paint (acrylic or alkyd paint)
- Clear coat for protection
I hope this helps!
V
vinli
9 Jul 2015 09:57
erikpu schrieb:
Preparation is crucial: thoroughly clean the surface, lightly sand it (with fine sandpaper, around grit 220) to create some texture so the paint adheres better.
Exactly, a structured process is helpful here:
- Remove doors and fronts so all sides can be painted evenly.
- Thoroughly clean the surfaces with a grease-dissolving cleaner, such as denatured alcohol or isopropanol.
- Sand the surfaces with sandpaper (grit 220-280) to roughen the smooth surface, which improves adhesion.
- Carefully remove sanding dust, for example with a lint-free cloth or a vacuum cleaner.
- Apply an adhesion primer specifically designed for plastics or laminates evenly.
- After allowing sufficient drying time, the actual paint can be applied; a water-based acrylic paint or alkyd resin paint is recommended.
- Apply several thin coats of paint, allowing each coat to dry thoroughly.
- Finally, a clear protective topcoat (matte, satin, or gloss depending on preference) is recommended to protect the surface against kitchen wear and tear.
If the surface is laminated, be careful not to use sandpaper that is too coarse, as this can damage the laminate. Additionally, there are special adhesion promoters that can be used as an intermediate layer if the primer does not adhere well.
For tools, a high-quality paintbrush, a foam roller, or a spray gun for spraying are suitable. For DIYers, spray cans are often the easiest option, as they apply the paint evenly without brush marks.
In summary: thorough preparation and the right paint technique are essential to achieve durable results.
Bepolo
10 Jul 2015 13:46
vinli schrieb:
For DIYers, spray cans are often the easiest option because they apply paint evenly without leaving brush marks.
I completely agree! Unless you’re a professional painter, using spray paint is really a dream. Of course, you need to work in a well-ventilated space, ideally outdoors in good weather.
A little tip I used: remove your cabinet doors from the frame, hang them up somewhere like in the garage, and apply thin coats with the spray. This way, you get a beautifully smooth finish, almost like something from a hardware store.
There are also paints nowadays specifically designed for furniture laminates that adhere very well – they even stand up to moisture in kitchens. Plus, you can choose from different levels of gloss.
If you’re choosing a color: classic white always works, but a dark anthracite or a soft pastel can really make a statement and freshen up the kitchen.
A small tip on the side: take your time and let the paint dry thoroughly. Patience always pays off with these kinds of projects 😉.
