ᐅ What modifications make Ikea Brimnes furniture more personalized?
Created on: 3 Dec 2023 08:37
par_meoHello everyone,
I am currently taking a closer look at Ikea Brimnes furniture and wondering what specific modifications can be made to personalize these pieces.
I am particularly interested in technical and aesthetic options that go beyond the standard assembly. For example: Are there any recommended modifications for the doors, drawers, or surfaces? What practical alterations to the Brimnes components make sense to better adapt them to different living situations or uses?
I look forward to hearing experiences and tips from the community related to customization that are ideally practical to implement.
par_meo schrieb:
I am especially interested in technical and aesthetic possibilities that go beyond standard assembly.This is the crux of the matter: Ikea places great emphasis on standardization, so the Brimnes furniture is designed with limited variability. However, there are definitely options that can be applied to make the furniture appear more personalized, such as:
- Replacing the handles with other models that fit the style
- Surface treatments like painting or applying adhesive films
- Modifications to the drawer fronts, for example with simple milling details
That said, it’s important to recognize that not every modification is compatible with the components. Are there specific examples we should consider for customization?
To address the question more specifically:
Ikea Brimnes furniture provides a solid base that allows for some structural modifications:
- Replacing handles: This is the easiest way to change the appearance, as the mounting holes are standardized.
- Changing the interior organization: Adding extra shelves or storage boxes.
- Adding LED lighting to enhance the interior.
- Painting or applying vinyl to door or drawer fronts to customize surfaces.
It is important to consider the material compatibility (particleboard, melamine coating) when painting or applying coverings to ensure durability.
Thierryzar3 Dec 2023 10:47A small but effective modification for Brimnes is replacing the handles. This immediately changes the appearance.
Installing internal organization systems also greatly improves functionality.
Surface painting should only be done with special furniture or plastic paint.
Curtis schrieb:
Ikea places great emphasis on standardization, so the Brimnes furniture is designed with limited variability.That’s exactly what I find interesting – the seemingly limited options often lead to creative solutions when customizing. I see it as a challenge, not a disadvantage.
If you’re looking for a piece of furniture with unlimited design freedom, Brimnes is not the right choice. But precisely because the individual elements are clearly defined, you get interesting details like playing with color, handles, and smart built-ins.
My advice: Don’t just change the appearance, but try to tailor the furniture functionally to your own needs – for example, drawers with dividers, installing soft-close hinges, or automatic door openers.
I would like to add that, in addition to common modifications like changing the handles, the back panels can also be altered.
Many Brimnes components have thin, non-load-bearing back panels that can be replaced with sturdier boards. This can improve stability and also provides an opportunity to customize the back panels with colors or patterns.
Additionally, I recommend fully removing any protective surface films before painting or applying coverings, and to perform sanding carefully to achieve better results.
A small reminder: the original furniture descriptions often include load capacity information, which should not be exceeded during modifications.
