ᐅ What common mistakes are often made when assembling the IKEA Hemnes furniture?
Created on: 31 Mar 2021 09:37
Jarren59
Jarren59
31 Mar 2021 09:37
I would like to start a more detailed discussion on the topic “What common mistakes occur when assembling IKEA Hemnes furniture?” In my experience, the assembly is generally manageable, but especially with Hemnes pieces, problems often arise that delay the process or ultimately affect the stability. Therefore, I am interested in which specific obstacles others have encountered during assembly. I often hear about misaligned side panels, incorrectly inserted dowels, or mix-ups with screw lengths, but I believe that is only part of the picture. I am also curious about the best ways to avoid these mistakes – for example, by carefully reading the instructions, thoroughly sorting the parts beforehand, or using particular techniques when tightening screws. Who can share actual difficulties and possibly offer tips for solutions? It would be especially helpful to hear experiences on how to identify typical errors early on, so you don’t end up with a damaged surface or a wobbly structure at the end of the build.
Timmyse36
31 Mar 2021 11:05
I had a similar experience assembling the Hemnes, and I learned how important it is to take your time and follow the instructions step by step. One issue that often caused me trouble was confusing dowels and screws because similar components are located very close to each other.
Jarren59 schrieb:
speziell bei Hemnes häufig Probleme auftreten
I think this note is very helpful because with Hemnes, the sometimes large solid wood parts add weight and stability – so if a panel is installed upside down, it not only looks wrong but also causes functional problems. It always helps me to double-check that all parts fit perfectly before tightening anything and officially “locking in” that step. Unfortunately, this doesn’t always happen when you’re in a hurry or assume you know the instructions well.
Does anyone else have tips on how to spot these pitfalls early? I sometimes consider taking photos of each work step to more easily identify sources of errors later on.
klo40
1 Apr 2021 08:47
Regarding common mistakes in assembling IKEA Hemnes furniture, I would like to list a few recurring points along with practical solutions:
- Incorrect arrangement of side panels: With Hemnes wardrobes and dressers, side panels are often installed mirrored or upside down. This becomes apparent later through misaligned holes or the framing of the front. It is essential to carefully compare with the instructions beforehand and possibly mark the wood accordingly.
- Confusing screws and wooden dowels: Although the instructions sort these out, it is easy to mix them up during sorting. My advice: arrange screws by length and thickness in small bowls so you can verify before each step that the correct screw is used.
- Cross-threading when screwing: If the angle is not precise, components can warp, which is particularly critical when installing the back panel.
- Installing the back panel too early or imprecisely: The back panel secures everything but is sometimes attached too soon. This makes later adjustments difficult or forces you to disassemble everything.
- Lack of alignment check before tightening: Especially with larger furniture pieces, it is advisable to loosely screw all parts first and then tighten everything finally to allow for corrections.
In conclusion, I recommend checking all parts and tools before each major assembly step and setting up a clean workspace. This small preparation often saves significant time and frustration.
Perhaps others can add which mistakes they particularly try to avoid.
Jeanbar
1 Apr 2021 14:18
This thread is really helpful because topics like these are often overlooked, and the Hemnes series is not simple to assemble.
Jarren59 schrieb:
What are common mistakes when assembling IKEA Hemnes furniture?
Here are a few points from my experience that I would like to highlight:
First, it is very important to follow the order in the instructions exactly. IKEA has designed the assembly steps so that certain hardware components can only be installed once the corresponding fit is correct. Despite the temptation to insert some screws early or pre-drill holes, it is better to avoid doing so.
Another common mistake is underestimating the holes: if the wooden dowels are not seated properly, this can later cause tension, which not only affects the appearance of the furniture but also negatively impacts its stability.
Surface care during assembly is also important for Hemnes. Fingerprints caused by pliers or scratches from slipping screwdrivers unfortunately occur more often than one might think. I recommend handling the parts with particular care and, if necessary, using soft cloths to protect the surface.
Finally, regarding stability: every screw should be tightened firmly but not overtightened. Otherwise, the wood can crack, which can happen with Hemnes if too much force is applied.
I hope these tips are helpful, and I look forward to more advice and feedback.
Timmyse36
2 Apr 2021 10:11
I would like to revisit an important point that was already mentioned in the thread by klo40:
klo40 schrieb:
Installing the back panel too early or carelessly: The back panel stabilizes everything but is sometimes installed too soon.
This was exactly the mistake I made in my last Hemnes project: I wanted to attach the back panel very early to make the furniture more stable, but as a result, it became almost impossible to make any adjustments to the alignment. The outcome was a slight tilt and a small gap at the bottom of the back panel. I then had to remove everything again, which cost me a lot of time.
My advice: Always install the back panel last and only when you are absolutely sure that all side panels are properly positioned and screwed in. This way, you stay flexible. Especially with multiple people involved in the assembly, it helps to communicate before locking the structure to check if any adjustments are still needed.
How do you handle this in larger projects with several helpers? Are there any specific routines to avoid these kinds of mistakes? Maybe someone can share a good strategy here.
