ᐅ What steps should I take to protect Ikea BESTA units from damage in damp or wet rooms?
Created on: 13 Apr 2024 08:17
TAUJE3
I am planning to use an IKEA Besta cabinet module in a damp area. Since the furniture is not originally designed specifically for damp environments, I am concerned about possible damage such as swelling, warping due to moisture, or mold growth. I am particularly interested in what specific measures I should take to protect the Besta cabinet from moisture as effectively as possible. Are there any special sealants, waterproofing methods, or installation tips that you would recommend? For example, what about additional ventilation options? The installation will take place in a bathroom without direct water connections near the furniture, but the humidity level will naturally be elevated. I look forward to practical and feasible advice.
Thank you all, I now have a much clearer understanding. My first step will be to carefully treat the edges and back surfaces with clear varnish, apply silicone seals, plan the installation on feet, and regularly check for any damage.
I will try to include ventilation through the baseboard despite limited space. If that is not possible, I am considering switching to moisture-resistant furniture.
If anyone has tips for specific products (varnishes, sealants), I would appreciate your recommendations.
PeoDaniel14 Apr 2024 09:03For sealing, I recommend polyurethane clear varnish. It is durable, water-resistant, and suitable for wood and particleboard. Make sure the varnish is approved for interior use and damp rooms. For sealing joints, sanitary silicone with mold resistance is suitable; it reliably keeps out moisture and remains flexible.
I would like to add that cabinets in damp rooms should be regularly ventilated, for example by opening the doors or temporarily removing the back panel, if the construction allows. This helps prevent moisture buildup inside. In case of generally high humidity, a small electric dehumidifier in the room might also be worthwhile.
