ᐅ What measures are recommended to prevent an Ikea BESTA from tipping over?
Created on: 20 Nov 2023 08:36
lidutra
lidutra
20 Nov 2023 08:36
I purchased an Ikea Besta wall unit, but I’m a bit concerned about its stability, especially the risk of tipping over. Since these pieces of furniture are often quite tall and narrow, I think it’s important to discuss preventive measures. My main question is: What measures are recommended to prevent the Ikea Besta from tipping? I am particularly interested in safety-related aspects, such as installing wall anchors, using expansion plugs, additional weight distribution, or any manufacturer recommendations beyond the included safety straps. Does anyone have experience and can share specific tips to improve the stability of Besta furniture in a reliable and effective way?
GALENKU
20 Nov 2023 09:02
The most important thing is to use the supplied wall brackets and securely anchor them into the wall. Additional tips: store heavier items at the bottom and avoid placing anything on the top surface whenever possible. This helps minimize the risk of tipping over.
kasan
20 Nov 2023 11:18
GALENKU schrieb:
The most important thing is to use the supplied wall brackets and secure them firmly into the wall.
I generally agree, but the question is how reliable the included brackets really are and whether they are suitable for all wall types. Drywall can be particularly problematic since standard anchors tend to fail quickly there. It would be helpful to have more specific recommendations for different kinds of walls. Additionally, I am missing an assessment of extra safety measures, such as using anti-tip devices that connect the furniture to the wall or floor. Tip-over is a serious safety risk, especially for children.
RENMA
21 Nov 2023 07:45
Based on existing manufacturer recommendations and technical standards, I suggest the following measures to prevent the Ikea BESTA from tipping over:
- Use the included anti-tip brackets to secure the furniture firmly to the wall.
- For drywall (plasterboard) walls, I recommend using high-quality hollow wall anchors to ensure adequate holding strength.
- Assemble the furniture as solidly and heavily as possible; this includes placing heavier items in the lower sections.
- Additionally, floor anchoring systems or non-slip pads under the feet can help prevent sliding and thus tipping.
This combination should be considered a standard approach and complies with common safety guidelines for furniture of this type.
PeoDaniel
21 Nov 2023 12:23
kasan schrieb:
It would be helpful to provide more precise recommendations for different types of walls.
Absolutely agree, that’s often where the problem lies. I’d also like to remind that some users want to install the mounting but lack the technical details or the right tools.
A few practical tips:
- For solid walls, the anchors and screws included in the supplied set are usually sufficient. Never just glue onto drywall panels.
- For drywall, heavy-duty hollow wall anchors generally provide much stronger support.
- Use a drill and appropriate anchors to attach to the wall. Installation isn’t difficult, and a spirit level helps find the best position.
- If you place the BESTA, for example, on carpet, non-slip felt pads or special anti-slip mats under the feet are recommended.
In summary: The combination of wall mounting, load distribution, and anti-slip measures on the floor ensures the best safety!
