FrankChief21 Apr 2023 08:46Hello
we are currently looking for a sofa
We want a U-shaped sectional sofa and it should be as large as possible.
I have attached the floor plan
Dimensions: Red approx. 355cm (measured from inside edge of tile base), Yellow 175cm (69.3 inches)
We have chosen a sectional sofa that is 352cm (138.6 inches) wide
This will fill the niche almost completely
What are your thoughts on this?
RotorMotor21 Apr 2023 08:49Is the house already built and the rough measurements taken, or is this just the plan? ;-)
FrankChief21 Apr 2023 09:06All measurements have been taken accurately.
353cm (139 inches) between the inner edges of the baseboards of the tiles
FrankChief21 Apr 2023 09:16355cm (approximately 140 inches) was the inside edge of the baseboard tiles.
353cm (approximately 139 inches) was roughly the size of the seating area.
The seating area is positioned relatively high, so it would still be quite accessible from underneath (height of the legs about 15cm (6 inches)).
The appearance can be considered as a point, but I find it hard to imagine how it will look in the end.
Unfortunately, the selection of good seating areas is limited, making it difficult to find a slightly smaller one, for example 345cm (136 inches).
andimann schrieb:
That looks really cramped, and if something falls between the sofa and the wall, you’ll have to pull out the whole seating area to reach it.
