ᐅ What type of mailbox do you have, and why did you choose it?
Created on: 12 May 2015 14:13
Panama17
we are currently planning our single-family home and the topic is the mailbox. My husband would like to have a slot in the front door with a flap on both sides, so the mail can simply be pushed or dropped through. I believe it doesn’t make much sense to install walls that are 46 cm (18 inches) thick and windows with triple glazing for thermal insulation, and then have an entrance door with a 30 x 8 cm (12 x 3 inch) opening in it. Or am I mistaken?
What types of mailboxes do you have, and what are your experiences?
f-pNo12 Jun 2015 09:28
the topic of the mailbox came up again for us in the past few weeks.
Again, because the saying has proven true: “Buy cheap, buy twice” – quite literally. We once purchased a freestanding mailbox with a newspaper compartment (including both posts) online for less than 40 euros. After somewhat complicated assembly, it was set up around November. In January, the anchoring of one of the posts broke off, turning the freestanding mailbox into a “mailbox standing in front of the door.” In March, the lock then broke – since then, the mailbox has been temporarily secured with tape.
Now that most of our outdoor area is completed, we are getting a new freestanding mailbox (the posts can be concreted in right away). This time we are going with a brand-name product, but we used online price comparison tools to find the mailbox about 30% below the normal retail and hardware store price (not refurbished). I expect that this will finally solve our mailbox problem.
Sometimes cheaper ends up being more expensive in the long run.
Panama17
12 Jun 2015 09:51
Yes, I have noticed that quite often as well, and by now I usually just avoid it. Not last time though—I bought a small pot for heating milk for €10 (about $11), thinking it would be enough. But no, that thing doesn’t even sit flat on the ceramic cooktop, so I bit the bullet and bought a better-quality pot for €22 (about $24).
As for the front door and so on, I already mentioned that’s not an option. Now the question is whether we should have a fixed panel or integrate the flush-mounted section into the entrance area. The architect wants to know next week already (just for your information, we don’t even have a hole in the ground yet; the tenders for the earthworks are only going out tomorrow :rolleyes 🙂.
The entrance area will be quite large, but there are also two light wells on the left and right of the front door, which complicates things again when it comes to a fixed panel.
Doc.Schnaggls
12 Jun 2015 10:01
Panama17 schrieb:
. Now the question is whether we choose a freestanding unit or integrate the flush-mounted mailbox into the entrance area.
With a flush-mounted solution, you should also consider that if the unit ever breaks for any reason, you will need to obtain a replacement part of the exact same size, unless you want to remove and replaster a large part of the wall.
In that case, I would rather opt for a freestanding unit or a proper surface-mounted mailbox.
Regards,
Dirk
f-pNo12 Jun 2015 10:09
Panama17 schrieb:
Now the question is whether to go with a freestanding unit or have the flush-mounted mailbox integrated into the entrance area.
Doc.Schnaggls schrieb:
With a flush-mounted solution, you should also consider that if the unit ever breaks for any reason, you’ll need to find a replacement of the exact same size—otherwise, you’d have to open up and replaster half the wall.
In that case, I’d prefer a freestanding mailbox or at least a proper surface-mounted box.
I personally also prefer a freestanding mailbox. Maybe I’m a bit particular, but I want to avoid any damage to the building envelope—even though we built with solid masonry without external thermal insulation composite systems (ETICS). Some interventions are unavoidable, but I try to be as careful as possible. If the house had ETICS, I would be even more cautious.
Are you building with a garage? You might consider mounting the mailbox there—after all, you’ll pass it every day when coming home from work. Otherwise, I would place a freestanding mailbox at the property entrance (which is what we are going to do).
