ᐅ What is the visible difference between hardwood flooring and laminate flooring?
Created on: 24 Sep 2012 15:15
Sophia
Sophia
24 Sep 2012 15:15
I had an apartment viewing yesterday. The agent wasn’t quite sure what type of flooring is installed: parquet, laminate, floorboards, or cork flooring?
Thank you in advance!
Best regards, Sophia
E.Curb
24 Sep 2012 15:36
Sophia schrieb:
And the real estate agent wasn't quite sure what kind of flooring was included: hardwood, laminate, floorboards, or cork?
I've often wondered what a real estate agent actually gets paid for.
Sophia
24 Sep 2012 15:40
Well, in any case, my actual question, which didn’t come across here, is HOW to recognize the difference. If the real estate agent doesn’t even know what it is, they could easily give me incorrect information!!!
TomTom1
28 Sep 2012 12:15
Hello!
This is a bit like the current Audi commercial: you can tell the difference by the price tag.
Otherwise, the goal with imitations is usually to make the copied product barely distinguishable from the original—and this is getting better all the time. While laminate flooring was once dismissed as cheap and future waste, the latest generation looks almost identical to wood, remains durable, and (unfortunately) has become somewhat more expensive.
Upstairs, we have three-layer engineered parquet in a ship deck style, and we're no longer very convinced by it (it’s very scratch-prone). Solid plank flooring often encounters structural challenges, among other things. The only really great option is our three-layer engineered parquet in a country plank design with bevels in the living room; but that also comes with a serious price.
When it comes to durability, laminate is unbeatable—but after all, it’s still “just an imitation.”
A reliable test remains the fingernail.
TomTom1
barcuda
29 Sep 2012 21:42
Solid wood planks can be identified by their length, 2 meters (6.5 feet) or longer. In contrast, laminate boards typically measure around 20 cm (8 inches) in width and 140–150 cm (55–59 inches) in length.
Solid hardwood parquet is recognizable by its joints, which create a consistent joint pattern across the surface, though on closer inspection, the individual joints vary. Each "parquet piece" consists of a single "board" with joints all around.
Besides classic laminate (wood imitation directly on a substrate, usually a compressed wood fiberboard), multi-layer flooring has become popular in recent years. This can also include multi-layer parquet with a 3–4 mm (0.12–0.16 inch) real wood wear layer. This multi-layer construction (similar to plywood, glued crosswise) can also serve as a base for higher-quality laminate or even cork, making them harder to distinguish. The multi-layer design offers the advantage of dimensional stability, making it particularly suitable for underfloor heating systems.
In my view, laminate is not the most durable option because water can penetrate through the joints into the wood fiberboard, causing localized swelling.
Personally, I consider multi-layer parquet to be the more resilient solution, as scratches do not penetrate through the top layer and the parquet can also be refinished.
BaumeisterBobby
8 Jan 2013 15:54
If it’s not clearly visible anyway, it’s not really a problem. And if the real estate agent doesn’t know either, you can still try to negotiate the price down using the argument, "This is not genuine."
