ᐅ What do you consider standard in a solid construction house?
Created on: 19 Apr 2019 00:18
neutronbx
Since we are currently choosing the right construction company for a solid (masonry) house, I have been eagerly reading through this forum.
What I have often read here is that you should expect around 2000€ per square meter (10.8 sq ft) for a standard build.
Now, of course, the question arises for me: what exactly does “standard” mean?
I would appreciate it if you could describe what you consider “standard” for:
- Shell construction (masonry)
- Electrical installation
- Windows and doors
- Flooring and tiles
- Heating system
- Sanitary installations (bathroom)
- Roof
- Other
I’m really looking forward to your answers 🙂
- Windows and doors
- Heating system
- Roof
- Other
Are you referring to us? In general, never sign anything early, and for special promotions with a preliminary contract, I would immediately consider switching providers. Unfortunately, too many people fall for that.
A verbal decision is made only after a detailed initial offer is presented to us, so the general contractor (GC) also knows they won’t be putting in effort "for nothing"—the initial planning takes several days.
We work with a local provider, where an offer comes from the architect and engineers as a preliminary service… This is of a different quality compared to a large-scale provider.
Only sign a contract after careful review and when all services meet your requirements. However, consulting is often a core issue here. It is either missing or frequently insufficient.
- Electrical
- Windows and doors
- Floors and tiles
- Heating
- Sanitary (bathroom)
- Roof
- Miscellaneous Shell construction: An energy-saving regulation compliant wall made of Ytong or Poroton blocks, plastered, without external thermal insulation composite system (ETICS), C25 concrete slab with strip foundations, ground electrode, bitumen membrane moisture barrier, welded, underfloor heating (UFH), fiber-reinforced screed, floating on base insulation, front door, side door, windows with branded PVC white profiles, triple glazing, front and side doors with glass inserts, 5-point mushroom-head locks, studio binder roof, Braas concrete roof tiles or similar in various color options, type Harzer Pfanne, matte finish, interior gypsum plaster except in sanitary areas, where lime-cement plaster is used.
Electrical: Sufficient power outlets, two outdoors, underground cables outside, satellite system with 2 TV sockets, telephone/DSL in one room of choice, alternatively one network connection in a room of choice, enough light switches and ceiling outlets, two outdoor lamp cables—one above each door, doorbell.
Floors and tiles: Flooring: Tiled flooring in utility room, kitchen, bathroom, and hallway, 60 x 30cm (24 x 12 inches) max, 25,- net per square meter; walls tiled in bathroom and kitchen splashbacks, same price; attic covered with boarding for walking access—rest is bare screed.
Windows and doors: Windows as above. Interior doors are white foil-laminated hollow-core doors, smooth with handles of choice.
Heating: Underfloor heating and gas boiler (Junkers), solar thermal system on the roof. One electric towel radiator.
Water – Bathroom: White branded ceramic sanitaryware (Duravit or similar), walk-in shower with flush floor tiling, fittings by IDEAL, 2 outdoor water faucets, one utility sink with water supply in utility room, connections there for washing machine, and in kitchen for dishwasher.
Miscellaneous: Plans, heat load calculation, building permit/planning permission submission, string line setout, rough grading of terrain, wastewater pipes connected to sewer system, including rainwater gutters finished in titanium zinc, solid red beech interior staircase with railing per selection, one Velux window in the roof, one patio door element.
This was our standard. K.
Tassimat schrieb:
Windows + doors: Double-glazed, no large-area windows or sliding doors. Today, triple glazing is more common, although it is a misconception that the number of panes is the main factor: double glazing does not have to be cheaper nor necessarily less insulating. There are also very different types of glass when it comes to solar and thermal protection.
