ᐅ What is the recommended screw sequence for assembling the Ikea PLATSA system?
Created on: 20 May 2024 18:27
teofe
teofe
20 May 2024 18:27
I am currently assembling the IKEA Platsa system, and I have an important question: What is the most effective order for tightening the screws during assembly to ensure stability while avoiding warping or uneven tension?
The instructions provide a basic sequence, but I wonder if there is a recommended technique for larger or connected modules—for example, whether it’s better to start with corner joints or the middle connections.
I’m interested in practical experience with tightening the screws, especially when attaching units together side by side or stacking them. Is there a preferred strategy to keep everything as straight and stable as possible?
I would appreciate any tips on how to handle the panels and side walls during assembly to prevent misalignment or distortion.
GiRoyce
20 May 2024 19:03
teofe schrieb:
Which screw sequence is really sensible when assembling PLATSA to ensure stability on one hand and to avoid warping or uneven stresses on the other?
That’s a very good question, especially with PLATSA, since the system is modular and flexible. My experience has shown:
- Always start with the corner joints and frames, as this provides the necessary basic stability.
- Screw the main load-bearing parts in lightly at first, meaning tighten the screws but don’t fully secure them yet. This allows you to adjust the piece and prevents tension.
- After setting the alignment, work your way step-by-step from bottom to top.
- When connecting multiple modules, prepare each module fully and align them as precisely as possible first.
- Only fully tighten the connection points between modules at the end.
The key with PLATSA is really not to rush tightening everything completely but to first pre-assemble everything loosely and then systematically tighten. This avoids twisting and uneven edges. This procedure is also recommended by furniture builders to distribute pressure evenly.
I hope this helps you already!
Domau0
21 May 2024 08:12
GiRoyce schrieb:
Always start with the corner joints and frame to ensure the necessary basic stability.
Exactly. To explain this in more detail:
I recommend assembling PLATSA in several steps:
- First, take all the parts and sort them by screw type and position.
- Then, loosely attach the corner and connector plates so the furniture can still be easily aligned later.
- In the second round, check with a spirit level if everything is straight — especially important for multi-part units.
- After that, tighten the screws gradually, turning each screw a little at a time rather than fully tightening each one immediately.
- For parts reinforced with dowels, fix the dowels first, then the screws.
- When connecting multiple modules, make sure all lower modules are completely level on the floor before tightening the connecting screws between modules.
Be sure not to overtighten the screws before everything is aligned, as this can cause stress on the structure that negatively affects stability — this is common with PLATSA because the panels are relatively thin.
If you need more details about specific connection points, just let me know. I can also explain the individual screw types used in the assembly.
Josefane
22 May 2024 09:34
Domau0 schrieb:
Make sure not to tighten the screws too much before everything is aligned, otherwise tensions can occur
I find this advice very important because it is often underestimated with modular systems like PLATSA. However, I would like to point out that this approach requires not only craftsmanship experience but also a certain level of precision in measuring and aligning.
It would be interesting to know if anyone works systematically with a specific tool to control the tightening torque or if it relies more on feel. When it comes to the screw tightening sequence, it’s not just about whether to start with the corners, but also when and how strongly each screw is tightened.
Furthermore, are there any opinions on whether all screws on one side should be pre-tightened before moving to the opposite side to avoid warping? That sounds logical, but does it actually make a difference in practice with PLATSA?
I sometimes question the conventional recommendations because the material thickness and connection techniques used in IKEA furniture are not always comparable to professional cabinetry. For me, an empirically proven method would be valuable to achieve the most stable and durable joints possible.
GiRoyce
22 May 2024 10:08
Josefane schrieb:
Are there any opinions on whether all screws on one side should be pre-tightened before fastening on the opposite side to avoid warping?
This is actually a proven method: first, you lightly tighten all fasteners on one side, check the alignment, and then repeat the process symmetrically on the other side.
This way, the pressure is distributed more evenly, and the piece is less likely to warp. Additionally, using some aids like small wooden wedges or spacers temporarily can help align edges and surfaces while tightening.
I apply this technique with PLATSA and have achieved noticeably better fit without screws tearing out holes or causing stress cracks.
Of course, it’s not high-end furniture construction, but for the price and design of PLATSA, this approach makes a lot of sense.
