ᐅ What is the most sustainable way to clean the Ikea Brimnes furniture?
Created on: 7 Nov 2019 09:07
luperaHello everyone,
I have several pieces of furniture from the Ikea Brimnes series at home and I am very interested in how to clean them in the most sustainable way. Specifically, I want to know which cleaning products and methods are gentle on the furniture while also being environmentally friendly, as I aim to avoid plastic waste and harmful chemicals.
I am aware of common recommendations such as using a damp microfiber cloth or a vinegar-water solution, but I am unsure what is advisable for the MDF or particleboard fronts and how often they should ideally be cleaned to maintain their durability.
Does anyone have experience or reliable advice on how to clean the Ikea Brimnes furniture most sustainably without damaging the surfaces or harming the environment? Thanks in advance for your answers!
lupera schrieb:
I know the common recommendations, like using a damp microfiber cloth or a vinegar-water mixture, but I’m unsure what is advisable for MDF or particleboard fronts and how often they should ideally be cleaned to maintain their durability.I can well understand how important sustainability is to you. Especially with furniture made from MDF or particleboard, it’s really a fine balance between keeping it clean and avoiding surface damage from harsh cleaning products.
Personally, I only use lukewarm water with a very small amount of biodegradable dish soap, applied gently with a soft microfiber cloth. Just wipe gently, not too wet, and then immediately wipe dry with a clean cloth.
My furniture still looks good after 2 years, and I feel this method takes good care of the surfaces without putting too much strain on the environment. The issue is that many eco-friendly cleaners sometimes don’t have enough grease-dissolving power, but I try to compensate by cleaning regularly rather than doing a very thorough cleaning only occasionally.
I’m interested in how others handle this, especially when there are children or pets in the household – where sustainability is of even greater challenge.
For sustainable cleaning of Ikea Brimnes furniture – which mainly consists of particleboard with a melamine coating – I recommend the following approach:
- Use a soft, lint-free microfiber cloth that is only slightly dampened.
- Mild, natural-based all-purpose cleaners or a mixture of water and a small amount of white vinegar are suitable for cleaning to balance the pH.
- Avoid abrasive cleaners, harsh chemicals, or solvents, as these can damage the melamine coating.
- Immediately dry the treated surface with a dry cloth to prevent the particleboard from swelling.
Regular, gentle cleaning prevents buildup and preserves the surface sustainably, since intensive cleaning actions can damage the protective layer.
Another sustainability aspect is the dosage of the cleaning agent: using too much leads to unnecessary chemical use and increased impact on the environment and the material. Cleaning gently several times a week is better than rarely and intensively.
In summary, a combination of mechanical care, pH-neutral or slightly acidic cleaners, and immediate drying is the most sustainable method. If necessary, test cleaning agents first on an inconspicuous area.
BEMAU schrieb:
Avoid abrasive cleaners, harsh chemicals, or solvents, as these can damage the melamine coating.This is an important point, as many believe that using stronger cleaners is more sustainable because it requires less scrubbing. In reality, aggressive substances can damage the surface, leading to faster wear—and therefore less sustainability in the long run.
Additionally, I wonder if a vinegar-and-water mixture is always safe: vinegar is acidic, and frequent use might affect the material.
Are there any precise measurements or studies on this? Many general cleaning tips are based more on experience than on scientific testing.
I would appreciate contributions based on concrete tests or manufacturer information. Only then can we be truly confident about how sustainable different methods are.
plo60 schrieb:
Also, I wonder if a vinegar-water mixture is really always safe: vinegar is acidic, and with frequent use it might affect the material.That’s exactly my concern – I’ve been wondering if using a vinegar solution, even in very low concentration, might cause more harm in the long run.
Lately, I’ve been using only plain water with a small amount of dish soap and feel that this works better. However, it requires more effort and regular maintenance.
Not everyone has the time and patience to clean that often, though. For those cases, a sustainable recommendation with minimal upkeep would of course be ideal.
Does anyone have ideas on how to better balance environmental friendliness with practicality?
