ᐅ What is the most secure way to attach IKEA Brimnes shelves?
Created on: 3 Feb 2021 09:07
jokiri
jokiri
3 Feb 2021 09:07
Hello everyone, I am currently planning to assemble an IKEA Brimnes shelving unit and have a somewhat specific question where I’m hoping to benefit from your experience.
The shelving unit has adjustable shelves that are normally fixed in place using the wooden dowels and metal supports designed for this purpose. However, I’m unsure about how to secure these shelves in the most stable way, especially considering the possibility that the unit might need to hold heavier weight or be subjected to frequent use.
I’m particularly interested in whether there is a method or specific installation advice for fixing the IKEA Brimnes shelves as securely as possible, to prevent sagging or wobbling.
I would appreciate it if you could share your tips or even modifications you have made, such as adding extra screws, brackets, or using a different type of fastening. Thanks in advance for your help!
Giagau
3 Feb 2021 10:22
jokiri schrieb:
I’m specifically interested in whether there is a method or special installation tips to secure the shelves of IKEA Brimnes most firmly, especially to prevent sagging or wobbling?
This is a very good question, as the standard fixing system in many shelves does have its limitations, especially under heavier loads.
From a technical perspective, the most important factor is the correct distribution of the load to the shelf and the connections to the side panels. In Brimnes, the shelves are relatively thin, so I recommend replacing the metal supports with more robust alternatives, such as metal brackets or even small angle connectors that are attached to the side and underside.
Additionally, placing thicker shims or a thin MDF panel underneath the shelves can help reduce sagging. Screws instead of the original wooden dowels provide significantly better hold if you pre-drill carefully and use screw plugs.
Another point is adding cross braces at the back of the unit, if space allows – this will greatly minimize any movement.
V
valentino
3 Feb 2021 11:47
jokiri schrieb:
Is there a method or special installation advice to most securely fix the shelves of the IKEA Brimnes unit, especially to prevent sagging or wobbling?
The construction of the Brimnes shelving unit relies on standardized wooden dowels and metal supports to hold the shelves, which is sufficient for moderate loads.
To increase stability, the following proven measures are recommended:
- Replace the plastic or metal supports with sturdy angle brackets (e.g., steel brackets) that can be firmly fastened with screws.
- Use screw plates or metal profiles beneath the shelves for additional support to minimize sagging.
- Add cross braces to stabilize the unit against lateral wobbling.
- When installing the wooden dowels, it is advisable to drill the holes very precisely with a drill bit of the correct diameter to avoid dowels fitting too loosely or too tightly.
Depending on your level of craftsmanship, combining several of these measures can achieve very good results.
relupa
3 Feb 2021 13:34
I find this topic very interesting because I have personally dealt with the problem of shelves sagging slightly over time.
Giagau schrieb:
replacing the metal supports with more durable options, such as metal brackets or even small angle connectors that can be attached to the sides and underside.
I can fully agree with that. I removed the standard supports on my Brimnes and screwed on small brackets instead, which feels much sturdier. At first, I was concerned that this might change the appearance of the shelf too much, but visually it is hardly noticeable.
valentino schrieb:
using screw plates or metal profiles under the shelves for support to minimize sagging.
That sounds technically sensible, but I have avoided it so far for aesthetic reasons. Maybe I will try it next time.
In summary, I would say it is better to invest a bit more time and reinforce the mounting if you want the shelf to last longer.
jokiri
4 Feb 2021 08:15
Thank you in advance for your detailed responses!
I believe my main concern is the long-term durability and heavy load capacity, so the suggestions involving brackets and metal plates are very interesting.
Would it be possible to replace the original wooden dowels entirely with screws? Is there any experience regarding whether the material (likely particleboard) can withstand this permanently, especially if various shelves are frequently removed and reinstalled?
Or are threaded inserts or special dowels a recommended alternative to standard wooden dowels?
Perhaps someone here already has a modified version of the Brimnes shelving unit that takes these details into account?
Giagau
4 Feb 2021 11:04
jokiri schrieb:
Would it be possible to completely switch from the original wooden dowels to screws?
Yes, that is basically possible and recommended by me, as long as it is done correctly. It is important not to overload the material: particle boards tend to tear out if the screw diameter is too large or if screws are placed too close to the edge.
Here are my tips:
- Pre-drill with a drill bit slightly smaller than the screw diameter.
- Use special particle board screws with coarse threads.
- Place screws as close as possible to the middle of the shelf board and not too close to the edge.
jokiri schrieb:
Or are threaded inserts or special anchors a recommended alternative to standard wooden dowels?
Threaded inserts are generally good but require precise and secure installation; otherwise, they lose grip quickly in particle boards. For shelves, they work better in combination with metal reinforcement.
In my opinion, the combination of screws and reinforced metal brackets is the most stable and practical approach.
