ᐅ What load capacity do the IKEA BRIMNES drawers have?
Created on: 3 May 2023 10:37
LONOKO
LONOKO
3 May 2023 10:37
Hello everyone, I am interested in the specific load capacity of the IKEA Brimnes drawers. I plan to use these drawers in my home office to store some heavy binders and documents. Since there are several versions of the BRIMNES series, I would like to know the maximum load capacity per drawer and how it performs in everyday use, especially with drawers being opened and closed regularly. It would also be helpful to get practical experience regarding whether the load capacity varies depending on the contents (e.g., books versus lightweight clothing). Are there any differences depending on the drawer type (e.g., 2-drawer vs. 3-drawer units) or material reinforcements? Thank you in advance for your feedback!
kautra
3 May 2023 11:05
The BRIMNES drawers usually support around 10 kg (22 lbs) per drawer. For heavier items, you should distribute the load or avoid overfilling to prevent sagging or warping. Three-drawer units are generally a bit more stable, but this guideline applies overall.
KUDAISY
3 May 2023 14:28
Hello LONOKO,
I would like to discuss this topic in more detail, as these drawers are often underestimated. IKEA generally specifies a load capacity of about 10 kg (22 lbs) per BRIMNES drawer. This is because the drawers are made from a wood fiber material (MDF / particleboard) and simple metal runners that are not designed to carry very heavy loads.
Tips for optimal use:
- Distribute the weight evenly, especially with heavier items like binders or books.
- Avoid concentrated pressure on thin MDF edges.
- If possible, use the lower drawer to support heavier loads.
- Check the runners regularly and tighten screws as needed.
A common issue is that many fill the drawers to their full depth without considering the weight limit. Over time, this can cause deformation and problems with opening and closing.
Another tip: The load capacity of different drawer types (for example, 2-drawer vs. 3-drawer units) is similar because their construction is comparable. Differences occur mainly due to how they are used and the overall design of the furniture.
In summary, I would say you can use the drawers well for medium loads, but for heavy binders, avoid overfilling or consider reinforced models instead.
boelnu
4 May 2023 08:16
I completely understand what you mean, LONOKO. Especially with practical furniture like the BRIMNES drawers, you want to be sure they hold up well in everyday use without constantly worrying about damage.
- Distribute the load evenly, especially with heavier items like binders or books.
- Avoid point loads on thin MDF edges.
- If possible, use the bottom drawer to carry more weight.
- Check the drawer runners regularly and tighten screws as needed.
That sounds really helpful, especially the tip about load distribution. I once had BRIMNES drawers too, mainly for clothing, and they held up surprisingly well. However, I did notice how the material changes over time when overloaded. I think it’s important to respect the weight limits and remember that this is an affordable piece of furniture. After all, you get a lot of storage space for a low price, which is a good compromise for many.
Hector
5 May 2023 17:43
I think it is important to critically examine manufacturers’ specifications in questions like these. IKEA often provides general load capacities—for example, 10 kg per drawer for the BRIMNES model—but this does not necessarily reflect actual load conditions in everyday use.
kautra schrieb:
The BRIMNES drawers usually hold around 10 kg per drawer.
This figure is a rough guideline without a clear explanation of how it was determined. A more detailed view shows that load capacity depends on factors such as the type of load (dynamic or static), load distribution, quality of assembly, and frequency of use. In addition, temperature fluctuations and humidity can affect the material’s stability.
Therefore, I would recommend not relying solely on the 10 kg, but rather inspecting the individual piece of furniture and considering alternatives if higher loads are expected.
Are there perhaps more precise test results or personal long-term experiences here in the forum? That would be important to get a more realistic assessment.
